I have an intermittent rumble and slight grind and skipping feeling. It appears to come from the driver's side. I can be felt in feet. I just did my wheel bearing. I thought I messed up, when caliber and shoe are off it spins freely with no noise or grinding feeling. When it happens it almost feels like warped rotors or bad pads. But it happens without braking. It happens randomly. It also happens when hitting potholes at time. When it happened, I threw in neutral and there was no change. There is very little noise. note: when I first took off caliber, I had to press the piston to get it back on. The caliber isn't loose, but it didn't return to old position. Also, the boot is turned up. I'm going to post a video if possible. Also, I was going 85 MPH and you can feel the rumble, but it doesn't get worse with speed just slightly more consistent.
Jun 12, 2022 at 10:07 AM
