Engine, ECM and Ignition coil wiring?
2003 TOYOTA COROLLA
RT90601
Where is the ignition coil wire in a 2003 toyota corolla?? I have had the starter replaced and the battery, but car will not fire up once in a while, someone told me to see if ignition coil wire is loose??
where is it under the hood
Mar 23, 2008 at 8:02 PM
MMPRINCE4000
  • 8,548 POSTS
They use individual coil packs for each cylinder. Remove the plastic engine cover and you will see the 4 coil packs. They are bolted to the cylinder head. Here are the engine wiring diagrams with a guide to help you check them below.
Mar 24, 2008 at 4:57 AM
J.STIEG
  • 361 POSTS
I need a diagram of a coil on plug transistor for a 00 corolla. I think the transistor is part of the coil and not the PCM, Is that true?
Is this transistor PNP or NPN? also what is the base/trigger voltage value. Thanks!
Aug 11, 2020 at 4:21 PM (Merged)
HMAC300
  • 48,601 POSTS
crank position sensor is 1630-2740oms cold and 2065-3225 ohms hot cold temp is 14-122F and hot is 122-212 F the oil is allone piece. there is also a cam sensor and this shold be scanned for codes and fuel pressure checked first if it doesn't run cam sensor is 835-1400 and hot 1060-11645 hot
J.STIEG
  • 361 POSTS
It runs fine, I would like to see a "wiring diagram" so I can learn about ignition systems. Thanks
There are 4 wires at the coil on plug.
HMAC300
  • 48,601 POSTS
the wiring daiagram that you seek wold be to small for me to send as it it 3 differnt pages and covers the whole engine for obd2. get a haynes manual for that
J.STIEG
  • 361 POSTS
All I need to know is just the coilpack/transistor area alone. 4 wires, Is that something you can post, thank you.
HMAC300
  • 48,601 POSTS
that includes the whole harness i cold only seperate the coil pack nothing else because everything runs to the computer.
DICKPOTTHOFF
My daughters car had an intermittent starting problem. A very astute mechanic discovered that, after the car was wrecked, a previous owner/mechanic had just stuffed the ECU? (my mechanic called it the PCM) into the console without it being in its case or being secured it place. He fix it and it worked well. A year goes by, daughter in different city, and it starts to do it again. I am assuming a broken wire in the harness connecting to the ECU/PCM box. QUESTION: How do I get to this unit to replace the wiring harness(es). What is the best way to verify which harness is the culprit? Thanks for your help.
MHPAUTOS
  • 31,937 POSTS
Hi there,
This loom,is a one piece loom and changing it would entail basically stripping the car down to its near bear frame, so repairing the problem is a better option, if you run a diagnostic scan you may get a code that will reflect the problem and then we can have a better chance to identify the suspect wire/s start here.
mark (mhpautos)
J.STIEG
  • 361 POSTS
Go ahead and send the three pages anyway, I don't care if it is small. Thanks 00 toyota corolla 1.8l
HMAC300
  • 48,601 POSTS
also get ti through your head these are not transistors nor triggers this is not a boat it's a car and they are sensors.
BUILTROD
  • 4 POSTS
is there a fuse or some kind of power pack that supplies power to injector? I do have power to three injectors not to one, changed injectors at different cylinders to see if injector was clogged it worked fine at different cylinder. have spark at all spark plug wires everything worked fine before I powered washed engine. no power at wire that plugs in to injector
The black wire on the injector harness connector is the hot side-the one that don't have power get a jumper wire and splice into another injector harness connector black wire and see what happens
https://www.2carpros.com/forum/automotive_pictures/12900_injector_6.jpg
BUILTROD
  • 4 POSTS
also I forgot to mention check engine light is on now as well, if i use jumper wire will that screw up firing order of fuel injectors? again this all just happened after I washed engine, drove car around block then parked went to start a week later, thats when problems started
The black wire on each injector is the power-it won't affect the F/O of the injectors they all tied into a splice look at the diagram-
Also try pulling the code/s from the computer
BUILTROD
  • 4 POSTS
can you use some kind of jumper to get codes?
can you use some kind of jumper to get codes? You need a scantool/code reader......
PACIFICISLANDER
  • 240 POSTS
Need the wiring colors of the connector for the fuel pump/sending unit.
BUILTROD
  • 4 POSTS
I was just asking because I use to be able to use a paper clip and you could use it as a jumper at the plug on the inside of the car on GM models then the code would flash at check engine light. If it turns out your info. will help me to correct problem I will be happy to make a donation for your help. But right now funds are low as I am and have been out of work since Dec. due to F*%ked up economy.
Thank you
I attached the wiring diagram for the fuel pump. Looks like the supply wire off the relay is blue/black and the ground from the pump is white/black.
Let us know if you need more info. Thanks
Bud-if its driveable take it to Autozone they'll do it for free. It use to be that way yours is a 97 and it needs a scanner to pull the OBD2 code/s
PACIFICISLANDER
  • 240 POSTS
Kind of figure that out my friend just making sure. Thank you so much for the wiring diagram. God bless-
Yeah. That was a pretty simple one so I figured it was either a really weird issue or you were just making sure. Thanks for using 2CarPros. Talk to you next time. Thanks
PACIFICISLANDER
  • 240 POSTS
I change the fuel pump, now I don't need to use starting fluid to start it up. now it's stalling, idles pretty good for 2/3 minutes then start misfiring then shuts off/stalls out but you can start it up again without a problem and repeat itself. Cleaned the IACV.
Okay. We need to start with the basics on this. Let's run through this info and see what happens. The one thing that is not on here the would make sense is the purge valve is sticking. However, we can get to that if all these check out.
https://www.2carpros.com/articles/stall-at-idle
PACIFICISLANDER
  • 240 POSTS
Where is the purge valve located?
Unfortunately the manual is not giving me a specific location but it is either on the top of the charcoal canister or at the other end of the line on the intake manifold.
Take a look at this diagram and let me know what you find. Thanks
CHRIS DEPEW
Need a wiring diagram and fuse and relay diagram for fuel pump.
Good morning,
I attached the 3 wire diagrams for the fuel pump control for you below.
What is your issue?
PACIFICISLANDER
  • 240 POSTS
Cannot find the purge valve, I tried everything you suggested still it keeps stalling. would a transmission problem involved here? Thank you.
CHRIS DEPEW
They left wires open next to fuel pump plug. Burnt with lighter I guess to test. Car is getting 0 fuel. I am figuring fuse or relay. I am a tech. So I like to have the diagrams to diagnosis.
A transmission issue could cause a stalling but not from the sound of this one. This sounds like an air or fuel issue. Prior to replacing the pump was it stalling like this after using starter fluid to get it started?
If not, let's test fuel pressure again because I wonder if we fixed on issue with the pump but got another issue with a faulty pump.
Okay, got it.
Let me know if you have any other questions.
PACIFICISLANDER
  • 240 POSTS
It wasn't stalling when I use the starter fluid not until I change the fuel pump. could the fuel pump be bad? seem to me a fuel pressure issue. when it stalls it seems like it wants to start but won't catch unless I give starting fluid and then starts up then take it for test then it idles for a while then shuts off again. I'm fixing to quit on this issue it's a headache to the max, lol.
Based on that info, we need to test the fuel pressure because you can absolutely have a faulty pump right out of the box. It is not common but more common then you would want.
Let's follow the guide I attached earlier and see what the pressure is and we can go from there as that should give us the proof we need to condemn the pump.
PACIFICISLANDER
  • 240 POSTS
Thank you. Sir I will recheck the fuel pressure as instructed and give you further notice. thanks again.
TAZUL.CHOWDHURY
4age a/t 16valve engine wiring diagram and ECU control box number?
KHLOW2008
  • 41,814 POSTS
The best way to go about is to remove the original from the vehicle to get the part number.
Coupe . . .
Federal - P/N 896611258084 - $830.47 . .
Calif --- P/N 896611260084 - $830.47 . . . .
Sedan . . .
Federal - 896611249084 - $675.44 . .
Calif --- 896611249084 - $675.44 . .
Sounds great. We will wait to hear back. Thanks for the update.
ROB40
  • 6 POSTS
I need this back fuse box junction fuse and relay connector pin wiring with wiring colors location.
