Jun 24, 2023 at 11:53 PM
Door Locks not working when pushed to open only the drivers door opens?
2004 TOYOTA CAMRY
Hi All, I have also same problem with my Camry 2011, only driver door unlocks not all 3 passenger doors but they do all lock. Do we need change BCM completely or actuators of all 3 doors ? Please help.
If all of the door actuators went out at the same time, I would replace the BCM. Please let us know how it goes.
Jun 25, 2023 at 11:46 AM
Thank you so much for responding Ken. I appreciate your help here. Except driver side door, all other passengers' doors (including right side front door) are not getting unlocked either with fob or main side switch from driver door. Can you please point me where I can buy BCM for Camry 2011 and do I need to take help of mechanic or is it DIY? After getting a new one, do we need to program it? I heard BCM is very costly. again, thanks a ton for helping me here.
Jun 25, 2023 at 4:26 PM
Thank you for your response.. I appreciate your help here. Except driver door all other passengers doors do not get unlocked only they all lock. Can you please point me where I can get BCM? Is it DIY ? Or do I need to take help of mechanic to replace it ? I heard it needs to be programmed after replacing it ? Is that true ?
Jun 25, 2023 at 5:31 PM
They are not too bad money wise, just search eBay or google to find a preprogrammed unit and you should be all set. It is a DIY project for sure.
Jun 26, 2023 at 12:00 PM
Hi Vishwa, I am also in the same boat about Camry 2011, 3 doors not getting unlocked.
Jun 27, 2023 at 5:34 AM
Sorry, this is a thread for a 2004 car. Please post your new question here, you must be logged in. We need to start a new thread.
Jun 27, 2023 at 10:06 AM
@guru1985 - I was able fix the door lock issue. Did you resolve your car door lock issue?
Aug 21, 2023 at 6:14 PM
@Vishwa - can you please tell me how did you fix this? did you replace BCM? if so how did you find the exact /correct BCM online for the options that your car has? Online I see many different BCM's for same 2011 camry so unable to confirm which one to buy?
Sep 17, 2024 at 7:49 PM
Hi @Vishwa, can you please let me know how did you find exact part for 2011 camry, online I see many different BCM for same year camry, so unable to identify which one to buy
Sep 17, 2024 at 7:52 PM
This post is for a 2004 toyota camry not a 2011. Please post your new question here, you must be logged in.
Oct 2, 2024 at 5:52 PM
I had the same problem as that described by the OP. 2011 Toyota Camry has three doors that failed to unlock when auto unlocking but all four locked when auto locking. The probability of three doors simultaneously having the same problem ruled out the actuators. I tested all the fuses. The responses here were a rare resource and aided me in thinking about the BCM, which before this I had no clue what this was. One mysterious difference for my Camry compared to some other models is that perhaps the BCM and the Interior Fuse Box on the driver's side has an integrated BCM? That box was replaced and the problem was fixed. Thank you to all who contributed.
Feb 25, 2025 at 7:09 PM
@Christopher Ellis, I too have 2011 Toyota Camry LE and have the exact same problem as you. May I know how much the BCM for this cost and how much the mechanic charged to replace it?
Feb 26, 2025 at 9:32 PM
