Can you explain me the problem of this car please? It does smoke when you idle it.
Aug 26, 2018 at 6:17 AM
BUJAR
MEMBER
Here you go a video.
Video (Click to enlarge)
Aug 26, 2018 at 6:18 AM
DANNY L
CERTIFIED EXPERT
Hello, I am Danny.
Just a quick question. Does it do this all the time or does the smoke go away? I have attached a tutorial for you to view. Hope this helps and hope to hear back soon. Thanks for using 2CarPros.
Danny-
It does that every time sometimes it stops for a few minutes and then starts again.
Aug 26, 2018 at 11:38 PM
DANNY L
CERTIFIED EXPERT
Hello again.
How many miles are on the vehicle?
Danny-
Aug 27, 2018 at 7:49 PM
BUJAR
MEMBER
118,000.
Aug 27, 2018 at 11:10 PM
BUJAR
MEMBER
But the thing is when you start the car in the morning it does not smoke for a few minutes and then the smoke starts.
Aug 27, 2018 at 11:26 PM
CERTIFIED EXPERT
This can be normal, after the car is warmed up and you have been driving for a while do you see what smoke/steam? Thanks for the video it helps. Also, has the coolant level been low at all?
Thanks for answering back. The car does not lose any coolant or does not burn oil at all. When you are revving the car the smoke goes away as long as you idle it back the car starts smoking as shown on the video.
Aug 30, 2018 at 11:44 AM
BUJAR
MEMBER
It is like a blue smoke not white.
Aug 30, 2018 at 2:43 PM
CERTIFIED EXPERT
If the smoke is blue (hard to tell from the video it looks white to me) these cars had problems with the oil drain back holes in the cylinder heads getting clogged causing the engine oil to fill the cylinders heads and leak down the valve stems seals and into the combustion chamber. Can you remove the oil cap and use flashlight to see how much build up there is? Send a video if you can so we can see. Can I ask if the smoke ever goes away?
Aug 30, 2018 at 5:07 PM
BUJAR
MEMBER
Yes, the smoke goes away.
Aug 30, 2018 at 11:30 PM
BUJAR
MEMBER
Here you go.
Aug 31, 2018 at 1:05 AM
CERTIFIED EXPERT
Yep, you can see the build up inside the cylinder head. Lets remove the valve cover and take another video to confirm the issue. Here is a guide to help us get started:
I cleaned the EGR Valve and the car smokes less and the smoke goes away.
Sep 5, 2018 at 12:47 PM
CERTIFIED EXPERT
Were you able to get the valve cover off?
Sep 6, 2018 at 10:12 AM
BUJAR
MEMBER
Yes, I took it off and I cleaned that and now the car smokes less.The car when it is smoking it feels like it is shaking. It did this and before and I cleaned throttle body. I think something might be choking the car I need to clean the intake manifold as well but that requires a lot of work and I do not have enough tools to do that.
Sep 6, 2018 at 3:37 PM
BUJAR
MEMBER
But the car feels like it is choking only when it is idling and the smoke starts.
Sep 6, 2018 at 3:39 PM
CERTIFIED EXPERT
I am wondering if you have contaminated fuel? Has the car done this for along time or did it just start? Also, lets run the codes to see if anything comes up.
I do not know for how long the car has smoking because I bought it few months ago so I have no idea about it. I am thinking to buy an OBD eleven is that a good code reader? Thanks
Sep 7, 2018 at 1:26 PM
CERTIFIED EXPERT
Any reader that can pull codes is good. Lets start there and see what comes up.
Sep 8, 2018 at 11:31 AM
BUJAR
MEMBER
Okay thank you. I will let you know.
Sep 8, 2018 at 12:14 PM
CERTIFIED EXPERT
Please do we are inserted to see what it is.
Sep 25, 2018 at 9:49 AM
BUJAR
MEMBER
I did, I payed to get a diagnose and they said nothing comes up. Injectors are okay. They are saying that it could be EGR valve the electric part does not work.
Sep 25, 2018 at 10:07 AM
CERTIFIED EXPERT
Can you pull the spark plugs out and get a picture of the electrodes for me? I want to see if it is one cylinder are all of them. Please keep the plugs in line with the cylinder there were removed from.
Sep 26, 2018 at 10:11 AM
BUJAR
MEMBER
It is a diesel mate does not have spark plug.
Sep 26, 2018 at 10:14 AM
CERTIFIED EXPERT
My bad, I have seen low fuel pressure and fuel contamination cause this issue as well. You say it does not lose coolant? Looking at the video again it looks like coolant or normal condensation. Does it go away when warm?
Sep 27, 2018 at 11:34 AM
BUJAR
MEMBER
Sometimes it does go away and it does not lose any coolant or burn oil at all. I changed the oil before four month and I have not received any oil loss so I do not really know what is wrong with it.
Sep 27, 2018 at 11:51 AM
CERTIFIED EXPERT
If the smoke/steam goes away when hot then the steam is normal. Are there any other problems you see besides the steam?
Sep 28, 2018 at 11:46 AM
BUJAR
MEMBER
Sometimes the smoke goes away and it is blue not white. White it is steam in the morning only but blue smoke, sometimes it goes away after warmed up, or it gets worse.
Sep 28, 2018 at 12:14 PM
CERTIFIED EXPERT
It sounds like you have a broken oil control ring on one or more of the pistons. Can you touch inside the exhaust pipe (cold) and see if it is oily?
Sep 29, 2018 at 11:17 AM
BUJAR
MEMBER
No it is not oily at all. Could that happen from a bad glow plug or bad oil use ? Or I do not know.
Sep 30, 2018 at 1:14 AM
CERTIFIED EXPERT
I do not think a glow plug would cause it. More like water in the fuel. When is the last time you changed the filters?
Sep 30, 2018 at 11:27 AM
BUJAR
MEMBER
I changed them a month ago.
Sep 30, 2018 at 11:34 AM
BUJAR
MEMBER
It is all sorted. It had to do with the torsion value at the timing belt.
Nov 22, 2018 at 1:25 PM
CERTIFIED EXPERT
Torsion value? Not sure what this is? Also was the timing belt off a tooth?
Nov 23, 2018 at 12:07 PM
BUJAR
MEMBER
Hmm, it is adjusting the camshaft.
Nov 23, 2018 at 1:33 PM
CERTIFIED EXPERT
It sounds like the camshaft actuator, good find on that. Nice work, we are here to help, please use 2CarPros anytime.
Nov 24, 2018 at 11:17 AM
BUJAR
MEMBER
But the thing is like mpg it’s decreased but the fuel economy still the same as before ?
Nov 24, 2018 at 11:36 AM
CERTIFIED EXPERT
The MPG should be better give it a bit to relearn and recheck in a few days.
