Engine Oil Change and P0420?
2011 FORD F-150
317,000 MILES • 3.7L • V6 • 2WD • AUTOMATIC
That is normal from the fluid being thrown around.
No issues there.
Mar 22, 2020 at 1:13 PM
CANNON1349
  • 861 POSTS
Hey in reference to the P0420 above, can that occur due to an evap leak? I had that code and a gross leak evap code. I replaced the purge solenoid and both codes have disappeared, and engine light off but p0420 is now labeled as a historic fault if I scan the system.
Mar 25, 2020 at 9:48 AM
No, there is no connection of the codes.
The 420 may be cleared but will come back. It has to fail its own internal test 3 times and light will come back.
Clearing codes does nothing as the issue needs to be addressed.
Mar 25, 2020 at 9:50 AM
CANNON1349
  • 861 POSTS
I understand that, but I'm used to the p0420 coming back immediately.
Mar 25, 2020 at 9:52 AM
It should not comeback right away. It is a 3 trip reset. When you clear it, all it does is make the ECM forget the code.
Mar 25, 2020 at 9:54 AM
