overheating ?
2006 PONTIAC GRAND PRIX
JAMIEGARCIA
  • 10 POSTS
Hi so my 2002 Pontiac grand prix is overheating once again we changed the thermostat and radiator cap the first time it started this.its overheating only when stopped liked befor also we kept driving it and eventually it just stopped over heating untill the other day when we noticed brown gunk on the radiator cap .we flushed it out and got the brown gunk out now it overheats again any suggestions ?
Sep 3, 2019 at 2:28 PM (Merged)
sealer is always a bad idea. it clogs the radiator and needs to be acid flushed to get it out.
from overheating, you need a leak down test to confirm you did not damage the head gaskets.
Sep 3, 2019 at 2:29 PM (Merged)
JAMIEGARCIA
  • 10 POSTS
I never used a sealer at all and to flush it I used prestone im assuming the gunk in there was blocking the problem so it didnt overheat now that its out it overheats again . maybe a water pump?
JAMIEGARCIA
  • 10 POSTS
Also there is coolant in the oil so I dont think its a blown head
BBONNER32
On a long road trip I recieved the low coolant message. The town I got the coolant in did not carry the proper DEX-COOL antifreeze/coolant so I purchased a bottle of normal antifreezecoolant. After a few more hours of driving on the freeway (Average speed was about 70 MPH) I noticed the white smoke coming from the tail pipe. The engine was at normal temperature but I knew something was wrong because of the white smoke. I added more antifreeze but continued to lose it fast. The car seems to run fine but still smokes. I read an article that said the first step is to remove the intake manifold then inspect the gasket. My main question is the car safe to drive until the dissasembly occurs and repairs are made?. And how difficult is this process? I have not done a whole lof of car repairs but can usually figure stuff out pretty well. Or should I leave the repair up to a mechanaic?
Thanks,
Brad
MMPRINCE4000
  • 8,548 POSTS
White smoke out exhaust is either the headgasket or intake gasket, and needs to be repaired ASAP, as it will damage O2 sensor and convertor, and if leaking bad enough can cause the engine to hydrolock, where cooland leaks into combustion chamber and bends a rod or breaks a piston.
I would have a trusted mechanic diagnose it, first with compression test, then cooling system pressure test.
if there is coolant in the oil as you said, then it does have a blown head gasket.
the gunk must be pressure flushed with acid to rid it of the stuff and re gain flow.
JAMIEGARCIA
  • 10 POSTS
Any other suggestions ?
not until those are confirmed, especially the fact that you confirmed the head gasket is bad with coolant in the oil.
roy
JAMIEGARCIA
  • 10 POSTS
Im sorry I meant there is NO coolant in the oil
HENRYROXMYSOX
  • 5 POSTS
Car starts beautifuly the first time of the day. Go to start it again and it starts but when driving it would have issues. As I was driving it would randomly die. So I took it to advanced auto to read codes. Car was misfiring so I changed the ICM which fixed the misfire. Then the car ran good the first time. So o checked the fuel pressure and it was only at 30-35 psi. So o changed the fuel pump. Drove it for about 20 minutes and it was back to its old habit of trying to die while driving. It'll start but when it starts acting up the tachometer jumps and so does the fuel gauge. The low oil light, change oil soon, low gas, and battery light all come on. I can sometimes get the car to come out of it by putting it in neutral and try to keep the rpms up. And other times I can drove with two feet and keep the car running but sometimes it'll just die. The ignition switch is broken. Would that cause the anti theft to come on at certain points and kill the car? The car runs great til it gets warm/hot and then I start having issues. It doesn't overheat. The head gasket is fine. Any help is greatly appreciated.
we are still at the radiator needing to be flushed out for flow with a pressure treatment.
HMAC300
  • 48,601 POSTS
have the ignition switch fixed first then see if you still have problem.s also clean the throttle plate on both sides and iac hole with choke cleaner.
JAMIEGARCIA
  • 10 POSTS
There is no coolant in the oil I meant
same answer as above.
