Okay, well, to start with, with the key off, unplug the ABS module and leave it unplugged for now. The U 1120 is a Lost wheel distance message from ABS module. So, to make sure its not the ABS corrupting the CAN bus network. Fuse 18 and 33 are direct B+ Hot at all times, 23,26,32 all come through the ASD Relay. So, it's not activating.
The other code is for the Intake Air Temperature (IAT) sensor, unplug the sensor and check one of the two wires for 5-volts. I'm getting a diagram ready for you. Now the IAT sensor shares a ground with many other sensors, so it might be that the sensor ground is open somewhere and that's why the sensor is reading High voltage, or it might just be a bad sensor, but we'll check that next.
You'll have to test the wires, it doesn't matter if they look good, we have to know they can carry current flow, Guessing is not how to diagnose circuits, especially automotive control circuits. But start with unplugging the ABS module.
This is the IAT sensor on the boot that runs from the air filter box to the Throttle body, Unplug it and check for volts on one of the wires with the key On. It needs to be unplugged to test it.
Next check the resistance of the sensor itself, check the Ohms reading across the 2 pins of the sensor., And make sure it's not an open circuit inside the sensor. A shorted 5v Reference circuit will cause a no start condition.
Aug 12, 2023 at 9:51 AM
