Code p0336, Now all I get is puffing sound when cranking but start?
2000 CHEVROLET SILVERADO
242,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
The return or ground is the ECM. If you had the black lead in the connector and read the voltage you posted, then it is good.
Apr 10, 2021 at 3:42 PM
AKILLEON SAMPSON
  • 33 POSTS
Apologies Roy my multimeter wasn't reading properly.. I'm getting-0.06.
Apr 11, 2021 at 2:29 PM
What wire?
Apr 11, 2021 at 3:27 PM
AKILLEON SAMPSON
  • 33 POSTS
The signal wire.
Apr 11, 2021 at 3:32 PM
AKILLEON SAMPSON
  • 33 POSTS
Red lead on C.
Apr 11, 2021 at 3:33 PM
AKILLEON SAMPSON
  • 33 POSTS
Sorry that was on both.
Apr 11, 2021 at 3:34 PM
AKILLEON SAMPSON
  • 33 POSTS
(Battery) Positive red to pin 22 7v.
Apr 11, 2021 at 3:38 PM
Okay, I am confused.
Can you retest the voltage as I suggested?
Do you have 12 volts to the connector on terminal C or the light green wire?
Also, put your voltmeter leads in the connector. Red lead to C and black lead to B or the yellow-black. Tell me the voltage. It should be battery voltage with the key on.
Apr 11, 2021 at 3:48 PM
AKILLEON SAMPSON
  • 33 POSTS
The-0.06 is being displayed with red connected to C and black connected to B.. if I remove red and touch positive terminal I get 7v@ B yet C remains the same when touching -terminal.
Is this being done without ecm being connected?....
Apr 11, 2021 at 3:52 PM
Why? You must have the ECM connected. That is where the power comes from.
Apr 11, 2021 at 3:55 PM
AKILLEON SAMPSON
  • 33 POSTS
Just trying to be 100% clear so that I will be able to follow all steps.
Apr 11, 2021 at 3:56 PM
The ECM must be hooked with the key on for these tests.
Please retest?
Apr 11, 2021 at 4:04 PM
AKILLEON SAMPSON
  • 33 POSTS
It was tested with ECM connected and key on.
Apr 11, 2021 at 4:06 PM
The readings you previously posted were with it disconnected according to you.
Please clarify.
Apr 11, 2021 at 4:18 PM
AKILLEON SAMPSON
  • 33 POSTS
I did not state that I was clarifying that you weren't requesting it to be unplugged to gain access to the connector hence "is this to be done without ECM connected".
Apr 11, 2021 at 4:21 PM
As I stated earlier, the ECM must be hooked up and the key in the on position.
Apr 11, 2021 at 4:27 PM
AKILLEON SAMPSON
  • 33 POSTS
I also stated that I performed the test that way....so we have 0.06 @ C.. what's next?
Apr 11, 2021 at 4:33 PM
What is the voltage on A and C with the ECM hooked up and the key on?
C is the return to the ECM.
Apr 11, 2021 at 4:42 PM
AKILLEON SAMPSON
  • 33 POSTS
With red in C and black in A 14v.
Apr 11, 2021 at 5:08 PM
Black lead to C and red lead to B and read the voltage.
Apr 11, 2021 at 5:26 PM
AKILLEON SAMPSON
  • 33 POSTS
-0.11.
Apr 11, 2021 at 5:37 PM
B is missing voltage. We posted the diagram a ways back for the sensor and the wires that go to the ECM. You need to go to the ECM connector and verify no voltage on the wire. If there is not, the ECM is the issue. If there is voltage, the wire is bad.
Apr 12, 2021 at 4:10 AM
AKILLEON SAMPSON
  • 33 POSTS
Recently just changed the ECU. I will update next weekend when I restart working on it.
Apr 12, 2021 at 9:12 AM
Sounds like a plan.
Apr 12, 2021 at 12:39 PM
DANNY L
  • 5,648 POSTS
Hello again.
We haven't heard from you in a few weeks? Has any progress been made on your truck? Last we heard you were going to replace the ECU. Please keep us updated and let us know what we can do to help. Thanks again for using 2CarPros.
Danny-
Apr 27, 2021 at 1:09 AM
AKILLEON SAMPSON
  • 33 POSTS
Nothing.
Apr 28, 2021 at 5:23 AM
Keep us updated when you can.
Apr 28, 2021 at 8:00 AM
DANNY L
  • 5,648 POSTS
Hello again.
Has anything came of this? We are curious to know of any progress made or let us know if you need any further assistance. We are still here to help. Thanks again for using 2CarPros.
Danny-
May 30, 2021 at 1:42 AM
