Hello TRAVIS BUTLER2,
Looks like relays 14 and 15 are the same, at least on my end. I would try switching them and see if the fans come on.
If nothing changes, I would test the relays to make sure they are good and if so put them back for now.
You can also test the ECT circuit to make sure it is functioning properly. I know you replaced the sensor, but the reading depends on a low voltage reference from the PCM. If the PCM isn't getting the right signal, because it isn't sending out the right voltage in the first place, it will not turn on the fans.
The best way to check this is with a scan tool, do you have one? If so, you can bring up the engine temperature and the signal voltage.
If not, another way is to use a multimeter. There are 2 wires coming out of the ECT Sensor. The yellow wire is the signal wire that is being sent to the PCM. We want to measure the voltage on the wire. I have attached a wiring diagram for you.
You will need to back probe the connector with a pin on the yellow wire.
Put black lead on ground on battery negative and red lead on the pin. You should have a signal voltage of roughly 0.5 to 4.5 volts. You should never see 0 or 5.0volts.
This sensor is simply a resistor. 5 volts is sent from the PCM to the sensor. The sensors resistance increases as temperature increases, which lowers the voltage signal the PCM receives. The lower the signal wire voltage the hotter the vehicle should be.
This will tell us the PCM is sending the right voltage to the sensor and the right signal to the PCM. Key needs to be on but not started.
I will add a picture of the multimeter I have. If you don't have one you can pick one up at the auto parts store or Home Depot has them too. That's where I got mine from.
I am also adding the pins I use to back probe connectors. You can get them at Walmart in the craft section. You may also use a sewing needle and bend the end 90 degrees so you can push it into the connector.
So, I would try switching 14 and 15 and see if anything changes and check the voltage signal from the sensor on the yellow wire. Then test the other 2 relays to make sure they are good.
Here is a good article about a multimeter that will help:
Here is a video on how to back probe correctly:
https://youtu.be/Spy8AXlxVT0
Then we can rule out all of those as possible issues.
Please let me know if you need any help testing.
Thank you,
Brendon
Jun 8, 2023 at 1:10 PM
