Sounds like someone has been doing some alterations. These are the ignition wiring diagrams for the 2000 and 01, the coils are different with the 98-2000 using a coil with a single power feed and 2 control wires while the 01 used two coils with two power feeds. That really shouldn't be an issue, however if that is really an 01 engine, that could cause an issue as they changed multiple items in the engine control system and the engine itself between 2000 and 2001. What makes me suspicious is the number in the last image, that looks like a salvage yard number written on there for tracking and warranty purposes. Looking at the crank sensor and cam sensors, they look the same but the part numbers are different in the books which usually means the sensor was also changed in some way. Plus internal parts for some items are different as well, the camshaft for instance shows a different part number between 2000 and 2001 but uses the same cylinder head. The MAF is a different part between them as are other important parts. They are designated as a Beta 1 engine through 2000 and the 01 is a Beta 2 engine. To confuse things even more they changed things using the build date so a car built before 3/10/1999 used one engine while ones built after that date had different parts.
However if it was running okay prior to this things may be set up correctly but it also may have been a "well it runs, ship it" situation and something wasn't quite correct and has now caused a problem. What I would do is try to determine what that engine really is then at least you know what you have. For that I would find any numbers you can on the engine and see what those turn up online. If you can contact the people you got the car from they might be able to shed some light on the issue as well.
Dec 11, 2020 at 12:34 PM
