My Santa Fe began to intermittently have a no start and not turn over. All you hear was a fast clicking sound but whenever we jump started it would start right up. Had proper voltage coming from battery and alternator was charging.It got worse so we replaced the battery. After replacing battery car would turn over but not start. Have spark and fuel and after replacing battery the check engine light came on with codes 223 365 445 and 2106. Took it to the dealer and they could not start it so they did a compression and leak down test. They said the engine compression is too low to start and # one cylinder is leaking. Also believe something is definitely wrong within the electrical but can not diagnose it without it running. Compression dry test and firing order #1/150 #3/160 #4/155 #2/130. The car was running perfectly fine till now. What is the next procedure ?
Feb 28, 2016 at 11:00 AM
