No start
1998 VOLKSWAGEN BEETLE
117,092 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
BRANDONGIBSON160
  • 28 POSTS
Car will not run unless starting fluid is used. Fuel pump relay has to be jumped to get fuel pump on but it was working normal after the no start. Seems like the fuel system has shut down and will not deliver gas to plugs.
Jul 1, 2019 at 3:59 PM
Lets run the codes to see what comes up first. here is a guide to help us get started:
Jul 2, 2019 at 6:29 PM
BRANDONGIBSON160
  • 28 POSTS
P0725, p1850, p1854 and p1857 is what shows up. No tachometer movement while cranking suggests crank position sensor but previous owner said he "just put a new one on trying to fix it".
Jul 3, 2019 at 12:27 AM
Yep, the RPM sensor sounds like it is out. I would replace it with a OEM part. Here is the location in the diagrams below. Please let us know what happens.
Jul 3, 2019 at 11:52 AM
BRANDONGIBSON160
  • 28 POSTS
I was messing with the fuses and finally got the fuel pump to work normal but now I don't have fire. I've been meeting with fuses and relays trying to recreate the fuel pump not working and getting fire but no luck. Could the fuel pump have just been a bad fuse and could the no fire be completely unrelated? And I can make it give the p0322 code by unplugging the crank sensor and trying to start it. Now I'm back to where I started with no fire.
Jul 6, 2019 at 1:46 PM
No fire you mean no spark? does the engine crank over (starter working). Can you please shoot a quick video with your phone so we can see what's going on? that would be great. You can upload it here with your response.
Jul 7, 2019 at 1:43 PM
BRANDONGIBSON160
  • 28 POSTS
Yes, it cranks but never starts due to no spark. Would it still have spark if it jumped time? I checked the timing marks on the cam sprocket and the one in the transmission housing and they looked good to me. so i think it is still in time. Other than the cam and crank sensor, is there any other sensors that would cause no spark?
Jul 9, 2019 at 12:35 AM
Yes it will have spark if it jumper time, did you try a new sensor? OEM? the spark starts at the crankshaft senor, camshaft sensor.
Jul 9, 2019 at 10:28 AM
BRANDONGIBSON160
  • 28 POSTS
I did change the crank sensor and coil pack with no change. I am not getting battery voltage at the coil with key on. It jumps around between 8 and 11 volts. If i wiggle the ignition switch connector it changes how many volts it gets. I have 3 ignition switches, all 3 do the same thing. There is one pin on the connector that is broke. I'm going to try to connect another connector to it and see if that helps. Will be back with results after I'm done.
Jul 10, 2019 at 7:11 AM
Okay, there are fuses that run the system. lets check for power at each with the key on. here is the engine wiring diagrams so you can see how it works and which fuses to check:
Jul 10, 2019 at 10:36 AM
BRANDONGIBSON160
  • 28 POSTS
So putting in a new ignition switch connector didn't help. I did find that if I remove the relay for the fuel pump that it will get spark again. Plug the relay back in and no spark. I'm going to get a new relay and see what happens. I hope it is not the computer keeping it from getting spark when the relay is in.
Jul 10, 2019 at 3:18 PM
BRANDONGIBSON160
  • 28 POSTS
Realized that the engine will run on starting fluid with or without the coil pack plugged up. But only if the fuel pump relay is unplugged.
Jul 10, 2019 at 6:54 PM
It sounds like the relay is shorted. lets try a new one. Please let me know.
Jul 11, 2019 at 10:25 AM
BRANDONGIBSON160
  • 28 POSTS
I checked power to the fuses and im getting no power to fuses 29, 32 and 43.
Jul 12, 2019 at 7:02 AM
BRANDONGIBSON160
  • 28 POSTS
I get power to 32 and 43 until the fuel pump stops priming.
Jul 12, 2019 at 7:07 AM
BRANDONGIBSON160
  • 28 POSTS
New fuse in 29 gets power.
Jul 12, 2019 at 7:09 AM
Okay, did you try the new relay?
Jul 13, 2019 at 11:40 AM
BRANDONGIBSON160
  • 28 POSTS
Not yet. Haven't been able to get a new one yet and the parts stores pulled up the wrong one. Do you have a part number for the correct relay?
Jul 15, 2019 at 6:39 AM
Fuel Pump Relay - 1J0906383C - $83.33
Jul 15, 2019 at 12:35 PM
BRANDONGIBSON160
  • 28 POSTS
The one i pulled out says 167 on it. And it only has 4 prongs on it. Is it just the complete wrong relay or did they make different versions of it?
Jul 15, 2019 at 1:00 PM
That is normal, take a look at the new one to see if they match up.
Jul 16, 2019 at 9:24 AM
BRANDONGIBSON160
  • 28 POSTS
Put 3 new relays in and it still doesn't get spark when the fuel pump gets power. I'm thinking either it's wiring or the computer is messed up.
Jul 16, 2019 at 4:15 PM
BRANDONGIBSON160
  • 28 POSTS
It also pulls a bunch of codes about stuff being shorted to ground with the relay in.
Jul 16, 2019 at 4:17 PM
Yep it does sounds like the PCM is bad, lets try a rebuilt/used unit to see what happens. Also did you use the wiring diagrams in the post I left, how did it turn out?
Jul 17, 2019 at 12:32 PM
BRANDONGIBSON160
  • 28 POSTS
So now it has got to the point where I can't even connect my code reader to the car. Can i get a PCM out of a pull a part and put it in and it work if its a good one or would i have to have it flashed?
Jul 17, 2019 at 6:32 PM
Most of the time a used one will work, but you can order a rebuild unit and give them your VIN to be sure. Let me know
Jul 18, 2019 at 9:21 AM
BRANDONGIBSON160
  • 28 POSTS
Is the pcm behind the gauges or on the passenger side?
Jul 19, 2019 at 5:50 PM
Here is the location of the PCM. Check out the diagrams (below). Please let us know what happens.
Jul 20, 2019 at 10:45 AM
BRANDONGIBSON160
  • 28 POSTS
Hopefully going to get a pcm tomorrow so I will let you know what happens. Does it have to have the same numbers or anything?
Jul 22, 2019 at 10:17 AM
Yep, same numbers and it might need to be programmed to the car. Some used ones will work but it is not 100%.
Jul 22, 2019 at 10:59 AM
BRANDONGIBSON160
  • 28 POSTS
Put another PCM in and still nothing.
Jul 30, 2019 at 1:39 PM
We must have missed something. lets start over.does the engine crank over? Can you please shoot a quick video with your phone so we can see what's going on? that would be great. You can upload it here with your response.
Jul 31, 2019 at 10:02 AM
BRANDONGIBSON160
  • 28 POSTS
Yes it cranks over. I have all 3 versions of the fuel pump relay and tried them all. 2 coil packs and tried them both. 2 crank sensors and tried them both. 3 ignition switches and tried them all. The coil gets power but not putting out spark. I just dont get it. I'll add a video when I get a chance to take one.
Aug 2, 2019 at 12:28 PM
Does the engine have compression will it run on starting fluid?
Aug 3, 2019 at 9:53 AM
BRANDONGIBSON160
  • 28 POSTS
It did run on starting fluid but i haven't tried it in a while. I'm going to mess with the fuses some more and see what happens.
Aug 6, 2019 at 5:13 AM
BRANDONGIBSON160
  • 28 POSTS
The sound quality is bad. Here is a video:
Aug 6, 2019 at 1:01 PM
BRANDONGIBSON160
  • 28 POSTS
So fuses still don't change anything. Was able to get it to stumble a little bit on starting fluid. I'm starting to think maybe it has a fuel problem instead or both since it's hard to get it to start on starting fluid.
Aug 7, 2019 at 3:11 PM
It sounds like it has compression so don't worry about that. can you hear the fuel pump run in the tank for 5 seconds when the key is turned on without cranking the engine over?
Aug 7, 2019 at 4:29 PM
BRANDONGIBSON160
  • 28 POSTS
Yes the fuel pump kicks on. Everything is doing what its supposed to do except i can't see any spark. The coil pack is getting the power and everything it needs to work but it doesn't.
Aug 8, 2019 at 10:26 AM
BRANDONGIBSON160
  • 28 POSTS
Unless the plugs and wires are bad and that is why there's no spark.
Aug 8, 2019 at 10:28 AM
BRANDONGIBSON160
  • 28 POSTS
Checked power to fuses again and there is no power to fuse 32 with key on. Could this be my problem?
Aug 8, 2019 at 1:07 PM
