Will not start
1997 LINCOLN CONTINENTAL
AL DUARTE
Electrical problem
1997 Lincoln Continental V8 Two Wheel Drive Automatic 20000 miles
drove it to work parked it 8 hours later wont start there is no spark going to the spark plugs .
Apr 25, 2017 at 11:46 AM (Merged)
See below probable causes
https://www.2carpros.com/forum/automotive_pictures/12900_no_spark_1.jpg
STAYLOR52
97 continental 4.6l, after about 10 minutes of driving at road speed cruse on, the car looses power and kicks out of overdrive, the temp gage goes to zero, if the cruse is turned off the rpm comes back but hi rpm like it,s in limp in mode. the message center displays engine temp data error, and check traction control. any sugestions?
Scan the computer for code/s and check the coolant temperature sensor-
DONTKNOWDIDALY
what could be wrong?
my car wont start.the inside lights come on the radio also i was driving last night no problems but check engine light was flashing and its been burning alot of gas the last two weeks without any extra driving just normal routine. this morning nothing tried a jump im stuck
WRENCHTECH
  • 20,761 POSTS
The check engine light flashes to tell you to stop driving it before you do severe damage. You will have to start with retrieving the stored trouble codes and go from there.
MICHAEL MOSS
my lincoln town car wont start .it was running fine when i parked it last night. engine turns over ok...
Apr 25, 2017 at 11:47 AM (Merged)
DRCRANKNWRENCH
  • 3,380 POSTS
You should test the fuel pressure. Advance Auto and Auto Zone loan out the test kit to performa a fuel pressure check. The test fitting is on the fuel rail which is above the injectors.
