Removal:
The valve body assembly must be removed to gain access to and replace the transmission range sensor.
1. Disconnect the battery cables.
imageZoom/Print
2. Remove air cleaner assembly (1).
imageZoom/Print
3. Remove the battery hold down clamp and remove the battery (1).
imageZoom/Print
4. Remove the battery tray (1).
imageZoom/Print
5. Disconnect gearshift cable (1) from manual valve lever(2).
6. Remove manual valve lever.
7. Disconnect transmission range sensor connector.
8. Hoist vehicle.
imageZoom/Print
9. Remove oil pan bolts (1).
imageZoom/Print
10. Remove oil pan (1).
imageZoom/Print
11. Remove oil filter (1).
imageZoom/Print
12. Remove the valve body-to-transaxle case bolts (1).
imageZoom/Print
13. Remove park rod rollers (1) from guide bracket (2) and remove valve body from transaxle.
imageZoom/Print
14. NOTE: To ease removal of the valve body (1), turn the manual valve lever fully clockwise to low or first gear.
CAUTION: The valve body manual shaft pilot may distort and bind the manual valve if the valve body is mishandled or dropped.
imageZoom/Print
15. Remove manual shaft seal (2).
imageZoom/Print
16. Remove TRS retaining screw (3).
imageZoom/Print
17. Slide Transmission Range Sensor (1) up the manual shaft and remove.
Jul 2, 2018 at 4:39 AM
