First thing you need to do is have the codes read, Autozone does it free, Post the results with the code number(s). Even if the service engine light is not on, there should be freeze frame data stored.
If it won't make it to Autozone, buy a cheap scanner, they can be had for 30-40 dollars, a good investment, since they cover all cars sold in the USA from 96 on...
The lock may be an actuator in the door, test the wire with a vlotmeter, if ok and actuator does not move, replace it...This requires a special riveter for the large rivit at the door.
Oct 24, 2020 at 11:59 AM
(Merged)
