Are we talking about its cranking over and refuses to start or won't crank at all/nada
Cranking and no start do below:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
No crank/nada:
Could be the battery/connection, alternator,starter, starter relay, park and neutral position switch and ignition switch
May 1, 2017 at 10:13 PM
(Merged)
