Check the # 3, #5 and # 9 fuses (replace as necessary) then,
Check for power (12V) at the brake light sockets, when the brake pedal is depressed.
If no power there, check for 12v at the LT GRN wire at the "turn signal and Hazard light switch" when the brake pedal is depressed.
If no power there check for 12v at the WHT/TAN wire of the "turn signal and Hazard light switch" when the brake pedal is depressed. If there is still no power, suspect a faulty brake light switch.
If power exists at the WHT/TAN wire of the "turn signal and Hazard light switch," suspect a faulty "turn signal and Hazard light switch."
Jul 28, 2019 at 5:51 PM
(Merged)
