Speedometer not working
1998 DODGE DAKOTA
127,000 MILES • 6 CYL • 2WD • AUTOMATIC
The Speedometer doesn't work at all . We change a front and a rear sensor want else can it be.
Mar 2, 2010 at 10:09 AM
Lets check for power at fuses 11, 1, and 17 here is a guide and the wiring diagrams for the cluster so you can see how the system works and the fuse locations.
Check out the diagrams (Below). Please let us know what happens.
Mar 5, 2010 at 10:43 PM
TURBOJAY
Thanks for this post I had a bad connection at the cluster all i did was unplug the cluster and plug it back in, all fixed!
Feb 20, 2019 at 5:54 PM
DON SCH
my speedometer on my 98 dakota does not work between 0-65mph. It started off not working from 0-25 mph then gradually it was 35, then 45 and now 65 mph. could it be the gear on the cable going into the transmission.
Feb 20, 2019 at 5:55 PM (Merged)
I believe you have a vehicle speed sensor that is going bad. Has the check engne light come on?
TIM88
Changed speed sensor and speedometer still does not work. Also at the same time both brake lights are on red and amber . All of this happened at the same time.
BMRFIXIT
  • 19,053 POSTS
try to get codes that should help
check the ABS and the rear speed sensor
KRIDGERD
My speedodometer stopped working and my Haynes book doesnt say anything about the speedo. The tach and shifting seem ok. Originally it wouldnt work under 20 mph and then it just quit altogether.
Feb 20, 2019 at 5:56 PM (Merged)
Have the vehicle speed sensor checked out before you go behind the dash with the speedometer head-could be a 2nd sensor here.
CRHILL
The speedometer is not working, when I have it tested at AutoZone it comes up as the v.s.s. sensor.. Replaced it and it still doesn't work... Person recommended that I check the wires behind the gauges, it's all electronics, but when I was putting the fuel gauge back in I had left the keys in the on position and when I tried plugging it back in I heard a pop and all the lights went off, no fuse is blown so did I blow out that whole system or........?
Please help, I drive this car late at night and not knowing how fast I'm driving takes me 3 times as long to get anywhere cause without traffic I have to go really slow......
HMAC300
  • 48,601 POSTS
check fuses under hood and check bulbs in cluster. then have it scanned for codes for a body module problem. it stil may be a bad dash as well though.
JIMMYD820
I took out the instrument cluster to replace a bulb & when I put it back the speedometer quit working. Every thing else still works. It is pegged at 120.
You have shorted something. I hate to say it, but you may need to recheck the wiring (plug) that you removed to get the cluster out.
JEFF0011
Please help with problem of you can
CARADIODOC
  • 34,306 POSTS
Both speed sensors? There's one in the transmission for the speedometer and cruise control, and there's one in the rear differential for rear-wheel-antilock brakes, or that one and two at the front wheels for four-wheel-antilock brakes.
JEFF0011
I don't have cruise. But when I am at like60 and let off gas the speedometer moves to right speed then goes back down to zero.
CARADIODOC
  • 34,306 POSTS
Where were the sensors you replaced?
BIGDOG762
How do you check if your speedometer does not, where do you chech it
Check the cable that attaches to the rear of the speedo. Make sure it is connected. If it is, disconnect it and see if you can spin the inner cable with your fingers. If you can, chances are the cable is broken internally. If you can't and it spins when driving, there is a problem with the speedo itself.
KEITH.NIFKS
I can't figure out how to get to the speedometer cable to replace it. Is there a video that shows this process?
We don't have a video for that. Basically, you unscrew the cable from behind the dash and at the transmission. If goes through the firewall.
Let me know if you need further help.
MONTANATED
Engine Performance problem
1999 Dodge Dakota V8 Four Wheel Drive Automatic
Hi: I have a friend who owns a 1999 Dodge Dakota Sport 4X4. There are several problems going on here.
1. The ABS light and also the Emergency Brake Light has come on, and continues to stay on. We both have contacted a local repair shop, and was told that there should still be brakes that are operational. In fact, there is indeed brakes. The lights still stay on though.
2. The check engine light comes on, then goes off - repeatedly. We have tried using different grades of fuel. This helps, but only for a short time. We have also tried the product: Lucas Injector Cleaner. To no avail; the check engine light comes on again.
3. Then just recently, my friend was in an automobile accident, where he rear ended someone. The speedometer was working right afterwards, then all of a sudden - no speedometer. That is until the vehicle reaches about 35 to 40 mph. Is the odometer also directly connected to the speedometer, or what? The odometer has also stopped working. The odometer is a digital readout format. It does light up, just does not advance the accrued mileage.
What is causing these problems? Any and all assistance would be greatly and immensely appreciated.
Thank you in advance,
Ted Lease
Feb 20, 2019 at 5:57 PM (Merged)
BMRFIXIT
  • 19,053 POSTS
Sensor more like it
need a help of a scanner
with out codes its all guessing
get the codes and let me know
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
BROWN6218
speedometer doesnt work like its suppose.
Check and test the vehicle speed sensor
BROWN6218
were is the speed sensor at?
ANGEL
My 1987 Dakota truck speedometer is not working and everything else on the cluster works. I checked/traced the cable down to the transmision and everything looks good. Should I buy a used cluster and replace my existing one?
KJB
  • 4 POSTS
hey there,
thought this idea may help you. i have a 85 ram 150 custom that i am restoring. my speedometer went out as well. it was bouncing and wining really bad. first of all you need to take your cluster panel out so you can geat the cable were in plugs in to your panel through the fire wall.
un plug it and undo the cable hooks under the hood. pull your cable through the fire wall so you can crab it from under the hood. you want to get it as straight as possible for the next step. inside the main cable is a thin wire, with a pair of needle nose pliars pull the thin wire out all the way. you may have to twist it a bit on the other end (transmission end) their is an allen head that locks in. after you have pulled it out, grease it put oil inside the main cable. 10w40,slick 50 or general greese is fine. install in reverse order makek sure you turn the cable back and forth to get it to lock back in
CHRISTINAV
Electrical problem
1992 Dodge Dakota 6 cyl Two Wheel Drive
the speedometer just stopped working and the mileage wont register either
Check behind the dash and at the trans to make sure the speedo cable is connected. If it is, disconnect it from the speedo and lower the cable so a helper can watch it while you drive. Check to see if the cable is spinning. If it is, the speedo needs repaired or replaced. If it doesn's spin or spins slowly, the cable most likely needs replaced.
Let me know what you find.
BRAXTON42
i have replace the sensor on the tran, but the speedometer still doesnt work. is there something else i can try
Are you sure the speedo works from the speed sensor and not a cable on a 95? I'm sorry, but it's been awhile and I just want to confirm that it doesn't have a cable.
JWWHITE2
My son has a 1990 Dodge Dakota. The speedometer does not work but the odometer does. When you drive, you can hear a clicking in the dash that soned like a cam is hitting the speedometer cable but it will not register the speed.
BLUELIGHTNIN6
  • 16,542 POSTS
have you removed the instrument cluster to visually inspect the speedo cable and connection?
GAP DREW
  • 6 POSTS
My dad just bought a used dodge dakota and the last owner unplugged the speedometer cable. I have looked for that cable and where it plugs in and i can not find it. It may be on the transfer case or the transmission. Where is it?
On left rear of transfer case
CARADIODOC
  • 34,306 POSTS
But it's not a cable. It's a three-wire speed sensor.
Vehicle speed sensor
GAP DREW
  • 6 POSTS
thank you all so much i will tell you if i find it
KEITH.NIFKS
where is the speedometer senseor on the tranny. I cant find it? Is it on the tranny? My Haynes repair manual doesnt show it at all.
TOOOMANYTOYS
  • 513 POSTS
The speed sensor is located on the transmission tail shaft housing on drivers side. Unless its 4 wheel drive then its located on transfer case input. Still on driver side.
