Jul 13, 2020 at 7:33 PM
(Merged)
Crankshaft sensor location?
1999 PONTIAC GRAND AM
I bought a 93 grand am and put a timing chainin it and it won't start. it has fuel pressure a new crank sensor checked the coils checked the injector new plugs and fuel filter. it shows no engine codes any sugestions?
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems
with compression and valves opening and closing at the wrong time/broken or jumped timing
belt/chain.
belt/chain.
(Merged)
19 Crank Position Sensor Fault, Runs when it's cold but dies when it warms up, replaced a lot of sensors don't know what else to do.
(Merged)
I assume you have replaced the crank sensor?
Remove ign. module and have it tested at most autoparts stores for free.
(Merged)
Well The module that under the cover, I already tested it at Auto Zone and it ran fine, I've heard you have to put some kind of a grease between the module and the cover. I was gonna try to replace oxygen sensor cause it didn't read on the scanner.
(Merged)
