Crank no start?
1988 CHRYSLER LE BARON
199,999 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
JERRY ULLOA
  • 36 POSTS
So, I turned on the ignition no power at the coil.
Feb 2, 2024 at 2:23 PM
The power to the coil comes from the auto shutdown relay, did you replace it? If so, I would swap out the ignition switch. Also, check the fusible links by the battery.
Feb 3, 2024 at 9:57 AM
JERRY ULLOA
  • 36 POSTS
So, I was cranking the car over and noticed a spark coming from a ground wire by the valve cover, so I tightened it up but still no start. Do you think it damaged the ECM or ASD relay?
Feb 28, 2024 at 3:19 PM
JERRY ULLOA
  • 36 POSTS
So I was cranking the car over and noticed a spark coming from a ground wire by the valve cover so I tightened it up but still no start do you think it damaged the ecm or asd relay
Feb 28, 2024 at 3:20 PM
