Hello, recently my car started to make a clunking, banging and shaking.Mostly when turning or giving it gas. When I check over car I noticed CV axle had a lot of play on the left side. I removed and axle is definitely bad so I replaced the CV . I also replaced ball joint and upper control arm. I replaced Inner outer tie rods on both side as well. I test drove car and it's still doing it. It even feels and sounds worse at times. When shifting from park to drive or reverse it makes a bang noise now . It hadn't done that till new axle installed. My alignment and wheel position is way off just to note. Also to note when install new axle the plunger side pulled out alot but went back in.Can my new CV be bad or defective.
Apr 12, 2021 at 3:03 PM
