Welcome back:
According to Alldata, with automatic climate control, the left side actuator is located just to the left of the glove box. The directions provide are in pics 2 and 3. In pic 1, I highlighted what I am seeing.
________________________________
The last thing in in pic 3 indicates calibration. I looked up the process for you and found this for doing it without a scanner.
Alternate Method (without Scan Tool)
Note: Do not adjust any controls on the HVAC control module while the HVAC control module is self-calibrating. If interrupted, improper HVAC performance will result.
1. Clear all DTCs.
2. Place the ignition switch to the OFF position.
3. Install the HVAC actuator.
4. Connect all previously disconnected components.
5. Remove the HVAC control module fuse for a minimum of 10 s.
6. Install the HVAC control module fuse.
7. Start the vehicle.
8. Wait 40 s for the HVAC control module to self-calibrate.
9. Operate system and verify that no DTCs have set as current DTCs.
Apr 30, 2021 at 11:44 AM
(Merged)
