Now, I’m seeing this. When I put a test light to the positive terminal, it’s fine and lights up perfectly. When I put it to the negative terminal, it almost never lights up, and I don’t see that pulsation you would expect on that side. I checked the continuity, and there is continuity between the negative terminal wire, and the pin in the 14 way connector for the ignition coil driver wire. I also cleaned it a bit to help, but it didn’t do anything. What does this mean? I’m not getting pulsation which explains the no spark, but why no pulsation?
Jun 19, 2019 at 6:50 PM
