starter not working?
1993 BUICK LESABRE
154,700 MILES • 3.8L • 6 CYL • FWD • AUTOMATIC
TOMSTEVE
ok, this is a friends and i dont know much about buicks. the car cranks over strong, theres spark. cant say how good as it was late,dark, and raining when he called( used a screwdriver in a plug wire) and i went to see what i could do. he had drained the battery so i jumped it. it rolls over strong but acting like no fuel. he says this happened once last spring and the car had to sit for a few days before it would start, then didnt have a problem til tonight. one thing i did was disconnect the ground on the battery( and i cant even remember why, but there was a reason) and after i hooked it back up, it sputtered for a second then nothing.
any suggestions on where to start??
Aug 6, 2020 at 10:20 AM (Merged)
check fuel pressure first.
TOMSTEVE
im at 42 psi.
TOMSTEVE
got it runnin. unplugged the mass air flow sensor and the other 2 connections by it and it fired right up. pulled the mass air flow sensor and cleaned it with mass air flow cleaner. thinkin a new one is in order.
BILBONE
My car will not start,the solenoid will not even click with the key. The starter and solenoid work fine when I hot-wire it to the battery,however the car will still not start with the key in the on position when I do this. I also checked the fuses and they seem to be fine.
MASTERTECHTIM
  • 4,750 POSTS
is the security light on solid on the dash?
LOCALPOD
Electrical problem
1993 Buick Lesabre 6 cyl Two Wheel Drive 76568 miles
stater cable came off and was reconnected but stater would not kick in as though it was not getting any fire
JDL
  • 16,098 POSTS
I'd have to make sure the battery has a full charge and the connections are good. Is the theft/security lite on the dash, on or flashing, when you try to start? Any codes?
