Recently my car would not start when i turned the key. After turning the key like ten times or so it finally started. Then it really did not turn on anymore. It would not even crank. I checked for codes and i got code 58, which is security shut off. They told me the main suspect was a broken wire that runs from the ignition lock cylinder to down below the dash. Sure enough one of the two little wires was broken. And while i was at it, i also replaced the turn signal switch that sits in front of the lock cylinder. I put it all back together, plugged all the wires in the right place. But again, got a new key made, i checked the resistance on the new key versus the old key and it was off by less than 5 ohm's, but the car still wont start, in fact in wont even crank. Its acting the same way as before. The only difference is that now when i check for codes it does not give me anything at all, just code 12 over and over. So i know there is no security shut off going on, so what is the problem? Is there a step that i missed along the way? Any help is appreciated thanks.
May 12, 2016 at 8:38 PM
