I have a stalling problem. This started several days after power washing engine.
The car starts, revs, shifts, fine. But has intermittent staliing problem.
For the most part this happens after car is warmed up and after stopping at stop sign. Upon normal acceleration, the engine "abruptly" starts to stop (engine stoos quidkly with a thud/jolt) and may or may not quit depending on how quickly I take my foot off the gas. It starts right away and may or may not stalll again.
If I accelerate very slowly, it will not occur.
It runs fine once it gets through this low speed acceleration problem.
It did "miss" once at speed going on an entrace ramp.
It will also show similar symptoms at highway speeds if I put the pedal to the metal and it will die surge, die surge, until I let up on the gas.
Standard code reader at Auto Zone did not show codes. I replaced a couple of sensors (for EGR) but did not help. Unplugged the MAF but did not help.
Tune up etc OK.
Ford guy said he though valve problem i(internal mechanical problem) in trans going from 1st to 2nd gear but I drove it in first "1" (Auto) and it still does it. I happens any time from immediately to after its reving up to 5-10 miles per hour.
Took it to a trans place and they think it's electic
updated 5-10-09
I took the car to a small independent transmission shop after Ford wanted to charge me $3,500 to replace the trans. The guy said that there was no way that this was a mechanical problem. I was either a ground or some other problem. He connected his "code machine" ran a test of some sort which caused the engine to race plus whatever else. The bottom line is, it must have rebooted the system and the problem has gone away. No charge.
I went bach to Ford and told them I wanted my money back for the "diagnosis"
they did. But they said to pack sand. That they need to be compensated for their time even if they didn't know what they were talking about. Even I knew it wasn't a mechanical probelem.
So much for Ford trained mechanics. There are no mechanics today. If they
can't plug it into the machine and have the answer spit out they're lost.
You need some common sense and ability. The problem they stated couldn't have been true had they thought it through but they sure wanted $3,500 bucks.
Feb 11, 2019 at 6:58 PM
(Merged)
