No, that wouldn't be a jumper wire. Looking at the schematic, the yellow comes from the battery to relay 2. When relay 2 is triggered, power from the yellow wire runs to the pink wire with a gray tracer which goes to starter relay 1.
The only wire colors at the starter relay (1) should be:
pink with a gray tracer
yellow with a gray tracer
dark green with an orange tracer
black
If the solid yellow wire from the battery isn't there, it must have fallen out of the vehicle.
Starter relay 2 should have the following wire colors to it:
Yellow
Pink with a gray tracer
Pink with an orange tracer
Black
Take a look below. Note that the power to relay 1 isn't provided directly from the yellow wire but rather indirectly when relay 2 is triggered.
Let me know if this helps. Also, if you can, take a pic of the box from a straight-on position of the bottom. I'm struggling to orient myself looking at it from the side.
Also, I attached one of your pics below. I pointed and circled in two places which I believe are yellow with a gray tracer. That is what goes from relay 1 to the starter. I have arrows pointing to others. Are any of those a solid yellow wire?
See pics below.
Jan 15, 2022 at 8:11 PM
