yes a vacuum leak can contribute to this problem , but what I wanted to say is, the oxygen sensor circuit is low, is what the scanner says, which means the harnass or the wiring, does not have a good connection, therefore the computer isnt sending the vehicle into complete closed loop, hence the lean condition. and the fuel pressure is a little too low , I would also check the air intake temp sensor, and fuel pressure regulator if you havent already. and the engine coolant temp sensor, and remember bad sensors wont always cause a check engine light,(one of the bad things about obd). keep me posted
Oct 16, 2020 at 11:44 AM
(Merged)
