So strip off the connector and hard wire into the clutch? That's another option.
We're gonna first attempt a better solder job with heat shrink and interweaving the two wire ends together. I also noticed a mounting clip got brittle and broke, and that's what gave the cable so much play to where the wire broke loose. So I'm gonna get that properly mounted again. If that ends up breaking loose again, I think I'll get the connector from a junkyard with as much wire as possible attached, and splice it at the same point it normally splices onto the main harness. I'd rather avoid having to hard wire anything since if that ends up breaking loose, I could need to replace the clutch assembly.
Jun 10, 2020 at 2:03 AM
