Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Chevrolet
Uplander
Climate Control
Air Conditioner
Compressor
Relay
A/C compressor will not come on unless relay is jumped
2008 CHEVROLET UPLANDER
247,000 MILES • 3.9L • V6 • 2WD • AUTOMATIC
PREV
1
2
NEXT
CERTIFIED EXPERT
20 lbs on the low side is the pressure needed to turn on the compressor.
25 to 30 lbs is the number for low side. You need an expansion valve.
The electrical issue is separate
Jul 26, 2019 at 5:23 AM
JASON123177
MEMBER
The very first thing I done in this process was to change both the front and rear expansion valves.
Jul 26, 2019 at 5:28 AM
CERTIFIED EXPERT
I saw that but the pressure indicates it is not working correctly.
Jul 26, 2019 at 5:37 AM
CERTIFIED EXPERT
What are the pressures withe the engine off
JASON123177
MEMBER
I will check the pressures when I get home this afternoon and let you know. Thank you again for all of your help!! It is very very appreciated!!!
Jul 26, 2019 at 5:41 AM
CERTIFIED EXPERT
You are welcome
Always glad to help
Jul 26, 2019 at 5:52 AM
CERTIFIED EXPERT
You are welcome
Jul 26, 2019 at 5:54 AM
JASON123177
MEMBER
The static pressure on both sides is 100psi
Jul 26, 2019 at 2:55 PM
CERTIFIED EXPERT
There is something wrong with that front expansion valve.
Jul 27, 2019 at 11:11 AM
JASON123177
MEMBER
That’s just wonderful.
Jul 27, 2019 at 12:08 PM
CERTIFIED EXPERT
Sorry to tell you that but the pressure indicates that.
Jul 27, 2019 at 12:13 PM
PREV
1
2
NEXT
