Okay. That is good info.
Let's do two things just to start crossing things off the list because if it ran when you parked it and you have fuel and spark now then we have to be dealing with old fuel.
We need to do it this way because I have wasted enough time to know it is always better to do it this way.
Disconnect the supply line to the carb and run it into a bucket or fuel can just because we don't want it going into the engine. If you can drain the bowl as well, then that is great.
Then change the spark plugs and use only starter fluid to start the engine with the new plugs installed.
Here is what I think is happening or at least we need to completely eliminate it as a possibility. The fuel is old and no longer able to combust properly, and the engine will not start or when it does, it stalls quickly.
I bet we have now fouled the plugs and they are wet with fuel and not able to start the engine at all. Once they are fouled, it is unlikely they will operate properly to get the engine to start so we need to change them.
So, we had old fuel, the engine flooded and fouled the plugs and now it won't start.
So we need to prove this by changing the plugs, and using known good fuel/starter fluid will get the engine to start and then it will stall once the fuel runs out.
However, at that point, you can drain the tank and if you have an inline filter, change that, and put new fuel in and you should be good to go.
Jan 16, 2022 at 11:22 AM
