I was worried my steering would be off balance, but I had locked the steering wheel and tied it down with the seat belt, prior to removing the coupler. I drove around on the interstate for about an hour, and the steering seems
There are a couple of difficult parts on the starter removal/reinstallation:
1) getting the lower bolt on the intake muffler (the belly of the muffler is in the way) I had to use a 1/4" extension to access it, but it took a long time to get it off.
2)getting the main power supply off the solenoid. it has a protector on it. i had to cut it off, before being able to get the clips off to remove it. but you can't fit a socket/wrench on the nut without getting that protector off. you'd probably have to remove the supercharger to get it off intact. the power supply cord sits towards the passenger side on the other side of the solenoid, so you can't see it when you are taking it out or putting it back in. I unbolted the starter first, before taking off the lead, because I couldn't see it.
3) repositioning the power supply to the solenoid back when putting back the starter, and getting it to fit into its position. hooking the power supply back up to the solenoid is difficult, because it's a tight space. I had to simultaneously put the lead on as I positioned the starter, because otherwise you wouldn't get it on there and get the wire in the right place. and if it's in the wrong place, then the intake muffler doesn't fit back in.
4)removing the steering coupler, very tight space, and you need two wrenches socket, cause there's a bolt on one side and a nut on the other side.
5)dealing with the factory hose clips. there's a learning curve for using the tool to get the clips to do what you want them to.
Aug 27, 2020 at 6:23 PM
