Hey, thanks. I did not know about your community, thanks for letting me know about it.
So, I've been trying to figure out what's going on with my AC, it's not blowing cold at all. Normally, this is not something I work on myself, but I took it to a oil change shop, they said there was no refrigerant in the system, and filled it up w 2oz and added some dye, but that's all they did. After that, the AC is still blowing hot air (not even a little bit cold).
I checked the Fuses 41, 51, and 30. Those fuses look fine. Are there other fuses to check? Do you know where the RELAY is for the Air Conditioner?
I was told I can check the error codes on my climate control console. I tried pressing the Defroster + Re-circulation buttons and then turning the car key to ON position (something I found an a forum). This seemed to do something, but I didn't see anything on the display. Do you know the procedure for this?
May 3, 2016 at 10:28 AM
