My vehicle initially shut off. I took it to the dealer. the cleaned the throttle body and IAC valve. It ran better and they suggested changing the IAC valve if it happened again. Well it did die out again and I changed the IAC valve. It would not start. I put the OBDII scanner on to check for codes and no codes. previously there were NEVER any codes present. While the tester was hooked up I tried starting the van bt accident and it started up with the tool plugged in. I pulled the scan tool itself and left the cord on and the van continued to run with just the cord plugged in. Cord gets warm a little. Once I pull the cord it dies out. I am thinking the ECM is bad. my vin is 4T3ZF19CX1U400816. 2001 Sienna automatic V-6. this is a link to a site with the ECM I found with my correct vin and model # http://www.toyotapartszone.com/online/Page_Product/PartDetail.aspx?vinnum=4T3ZF19CX1U400816&VAID=1562&productiondate=200106&catalogCode=622410§ionID=4&isBigPicture=False&componentsID=84-04&componentsIndex=13
May 22, 2010 at 2:36 PM
