My engine stalls at idle can you help me fix it?
2009 TOYOTA COROLLA
140,000 MILES • 1.8L • 4 CYL
J.STIEG
  • 361 POSTS
Can you also get me a wiring diagram for ignition coil (COP) #4 , there are four wires on it, 2000 corolla 2.8l
thanks
Jan 22, 2021 at 10:54 AM (Merged)
RIVERMIKERAT
  • 6,110 POSTS
2.8liter or 1.8 liter? Our reference shows only a 1.8 liter engine. Manual or automatic?
J.STIEG
  • 361 POSTS
I meant to say 1.8l, and it is a manual drivetrain.
I need to check wiring on the #4 coil, It got four wires going to it. Thanks
J.STIEG
  • 361 POSTS
Is there any thing with the coil circuits that would keep the injectors from firing.
trying to get the injectors firing again.
Injector fire for the first 2-3 seconds then shut off.
RIVERMIKERAT
  • 6,110 POSTS
That sounds like an ASD, automatic shutdown relay.
WRENCHTECH
  • 20,761 POSTS
[quote]That sounds like an ASD, automatic shutdown relay.[/quote]
If it was a Chrysler product maybe but Toyota doesn't have one.
J.STIEG
  • 361 POSTS
I will check on ASD, but that would cut spark too wouldn't it.
I have good spark.
code #P1315 comes back right after it is erased. Not shure if thats injector related or not.(imputs affecting computer possibly?) .
Here is another note: when I turn the ignition on and start it will run for two seconds.
After it stalls and I attempt to restart it, it wont start up unless I turn ignition off and turn it on again, then that achieves another two seconds of running before injectors cut out again.
RIVERMIKERAT
  • 6,110 POSTS
P1315-Ignitor #4 circuit.
J.STIEG
  • 361 POSTS
Why is there 4 wires on all the coils?
WRENCHTECH
  • 20,761 POSTS
Because it's transistorized. It has constant power and ground and 2 wires to the ignition module. I gave you the wiring diagram so you could see that.
J.STIEG
  • 361 POSTS
I think the fuel shut off problem is occurring because of a bad IGF signal coming from the coil going to the computer.
Spark Confimation IGF
Once a spark event takes place, an ignition confirmation signal called IGF is generated by the igniter and sent to the ECU. The IGF signal tells the ECU that a spark event has actually occured. In the event of an ignition falt, after approximately eight to eleven IGT signals are sent to the igniter without receiving an IGF confirmation, the ECU will enter a fail safe mode, shutting down the injectors to prevent potential catalyst overheating.
So I guess I need to test the IGF circuit.
Can you get me pin numbering on the ECU connector. Thanks
J.STIEG
  • 361 POSTS
I think I'v got em, just have a hard time with the charts but I see it.
J.STIEG
  • 361 POSTS
Ok here is where I'm at, I go to the circuit I suspect which is the "IGF circuit" and do a continuity check.
Here is what I find: checking at the ECU E4 pin #3 l/y...TO...ltblue/yel at any given coil, and there is no continuity at all, Good news I think, well we will see.
There is good continuity from coil to coil.
I suspect open between IGF junction and ECM.
I wonder why its throwing code for coil #4 and not all.
Going to open up the harness a little more and do some more testing tomorrow, Keep your fingers crossed.
RIVERMIKERAT
  • 6,110 POSTS
Ok. Let us know what you find out.
J.STIEG
  • 361 POSTS
Good news the problem Is solved. I was wrong about that one IGF circuit between the ECU and coil, it had good continuity.
The problem was I one of the coils.
I kept changing the coils around and codes followed the coil.
I bought a used coil for $35 and car runs, and stays running.
RIVERMIKERAT
  • 6,110 POSTS
Great! Happy to have been of service. Please tell your friends about us.
Closing thread.
JAMES MALONE
Just wanted to say thank you for this. I had this EXACT same problem, with the same car, and this was the fix for me. This was the only thing I could find with countless hours of diagnosing and googling.
DANNY L
  • 5,648 POSTS
You're welcome !
Please feel free to use us again in the future.
Danny-
