What is that attached to on the right hand side of your pic? Here are the directions specific to your vehicle. Take a look through them and let me know if they help in any way. As far as the pic, I believe that is a support between the engine block and transmission, but I'm not 100% sure. Also, please confirm something for me. You indicated this as a 3.0L V6. It should be the 2.7L. Is that correct? Also, let me know if it is a sedan or coupe.
2002 Dodge Stratus Sedan V6-2.7L VIN R
Procedures
Vehicle Starting and Charging Starting System Starter Motor Service and Repair Procedures
PROCEDURES
REMOVAL
1. Open Hood.
2. Disconnect the negative battery cable.
3. Raise vehicle and support.
4. Disconnect the electrical connector from the O2 sensor.
Fig.6 O2 Sensor
Pic 1
5. Remove the O2 sensor from the exhaust manifold (Fig. 6).
6. Remove the front mount through bolt.
7. Remove the front mount bracket from engine block.
Fig.7 Starter Motor
pic 2
8. Remove the battery cable from starter (Fig. 7).
Fig.8 Starter Motor Removal
pic 3
9. Remove the lower starter bolt and remove starter (Fig. 8).
INSTALLATION
1. Install starter to transmission.
2. Start the upper starter bolt.
3. Start the lower bolt and snug it so that the starter will not move.
4. Remove the upper bolt.
5. Connect the battery cable and torque nut to 8.5 Nm (75 in. lbs.).
6. Install the front mount bracket and check heat shield location.
7. Install bolt the upper bolt and torque bolt to 54 Nm (40 ft. lbs.)
8. Install the lower and torque bolt to 54 Nm (40 ft. lbs.)
9. Install the front mount through bolt and torque bolt to 61 Nm (45 ft. lbs.)
10. Install the O2 sensor and torque to 27 Nm (20 ft. lbs.)
11. Lower vehicle.
12. Connect the negative battery cable.
__________________________
Aug 3, 2020 at 1:40 PM
(Merged)
