That is correct, a cylinder 1 misfire. It is hard to believe that it needs spark plugs already, but anything is possible.
In this case, I personally would remove the number 1 spark plug to check its condition. However, I suspect we may have a coil pack beginning to fail or the valve cover may have a leak and getting the coil wet. I say that because a spark plug is usually either good or not.
If you are comfortable doing it, here is what we need to try. We need to switch the coil packs between cylinders 1 and 2. The purpose is to determine if the coil pack is the issue. If the coil is failing, the misfire (P0301) will move to cylinder 2 (P0302). If you still have a misfire at cylinder1, then we need to check the spark plug.
I attached 3 pics below. The first two are the directions for removing the coils. They forgot to mention you need to remove a bolt. LOL In pic 3, I highlighted the bolts.
You only need to worry about cylinders 1 and 2. Cylinder 1 will be the one closest to the serpentine belt (front of the engine). Simply, remove the plastic cover from the top of the engine. Gently pull upward on it. I don't believe there are any bolts or screws holding it. It should snap into place.
Once that is removed, you will see the coil packs. Switch them and let me know what happens. Also, pay close attention to the rubber part of the coil that attaches to the spark plug. If it is wet with oil, that could also be the cause of the misfire.
Let me know if this helps, if you have other questions, or if I can help in any way.
Mar 5, 2023 at 8:21 PM
