Engine randomly shuts off, sometimes I can drive for 5 minutes sometimes an hour?
1996 DODGE RAM
168,000 MILES • 3.9L • V6 • 2WD • AUTOMATIC
96DODGERAM
  • 63 POSTS
My truck shuts off at random I've replaced or cleaned a lot of parts. Sometimes I can drive for 5 minutes sometimes an hour and on some drives it doesn't shut off at all, but at least 3 out 5 drives it will shut off but it starts right back up. The last thing I switched was the ASD relay and I really thought that fixed it but the truck shut off on the way home from the store but didn't have any problems going there.
Jan 3, 2021 at 8:35 AM
CARADIODOC
  • 34,306 POSTS
When does this happen; only when idling or even when driving at a steady speed? Any history that led up to this? What have you done so far to identify the cause of the problem? Have you read the diagnostic fault codes? Has the engine ever failed to restart?
Jan 3, 2021 at 1:46 PM
96DODGERAM
  • 63 POSTS
It mostly does it at steady speed. I have hooked it up to a few readers and they all just tell me faulty o2 sensors, but my upstream o2 has been cut off by the previous owner. Everyone I talked to tells me that wouldn't cause it to shut off. 1 reader said the throttle position sensor was bad so I changed it still shuts off.
Jan 3, 2021 at 2:49 PM
CARADIODOC
  • 34,306 POSTS
You don't need a code reader to check the fault codes. Chrysler made doing that yourself much easier than any other manufacturer. Cycle the ignition switch from "off" to "run" three times within five seconds without cranking the engine. Leave it in "run", then watch the code numbers appear in the odometer display. You can go here:
https://www.2carpros.com/trouble_codes/obd2/p1500
to see the definitions, or I can interpret them for you.
Also be aware diagnostic fault codes never ever say to replace a part or that one is bad. They only indicate the circuit or system that needs further diagnosis, or the unacceptable operating condition. When a sensor like the throttle position sensor, or other part is referenced in a fault code, it is actually the cause of that code about half of the time. First we have to check for wiring and connector terminal problems, and mechanical problems associated with that part.
You're correct that the sensors you listed won't cause stalling. The throttle position sensor has about the least impact on fuel metering calculations. It's the oxygen sensor that concerns me. Its main function is to provide information so the Engine Computer can fine-tune the air / fuel mixture. What worries me more is of the over 2,000 potential fault codes, about half of them refer to things that could adversely affect emissions, as is the case with O2 sensors, and those are the codes that turn on the Check Engine light. While oxygen sensor codes could be relatively minor, with the warning light already on, you'll never know if a more serious fault code is set. You won't know it so it's going to be ignored. That could lead to more serious problems.
To add to the misery, there is always a long list of conditions that must be met for the computer to set a fault code. One of those conditions is that certain other codes aren't already set. The easiest example to explain involves the coolant temperature sensor and the intake air temperature sensor. The Engine Computer knows that after the engine has been off for at least six hours, both sensors had better be reading the same temperature. Failures of temperature sensors are extremely rare because they have just one component inside them. Instead, most fault codes related to them involve the wiring and their connectors. If you were to unplug, lets say the coolant temperature sensor, with the ignition switch on, the computer would see that, set the appropriate fault code, and stop using it as a reference for the intake air temperature sensor. Serious defects with the IAT circuit will still be detected, but the more minor tests the computer constantly runs will be suspended since there's nothing trustworthy to compare it to.
It's not until the coolant temperature sensor circuit is repaired that the air temperature sensor tests will resume. That is when any minor problems that developed recently will finally be detected. In the case of your oxygen sensor, one example it's used for is when the computer commands the charcoal canister purge valve to open, it expects to see a rich condition reported by the front O2 sensor. With no valid readings from the O2 sensor, the computer has no way of verifying the purge valve opened as instructed. The rubber hose could be plugged, or dry-rotted and leaking, but you'd never know.
There's a more direct way the oxygen sensor can be involved here. Depending on how the previous owner hacked the wiring to it, if the wire for the sensor's heater circuit fell down onto hot exhaust parts, it could short to ground intermittently. That harness falling down is already a somewhat common problem on many car and truck models. With a direct short, a fuse will blow, then the engine can't be restarted until that fuse is replaced. With rusty exhaust pipes, the short might not be solid enough to cause the fuse to blow, but it can drag circuit voltage down enough to cause other parts of it to stop working. The O2 heater circuit is tied in as part of the "ASD", (automatic shutdown) relay circuit that also feeds the injectors, ignition coil(s), alternator field, and fuel pump or pump relay.
Now that I described what could happen, we have to figure out what is happening. We know fuses aren't being blown. We know some defects that could provide valuable information aren't going to be detected. Based on your ability to restart the engine right away, we can probably rule out the crankshaft position sensor or the camshaft position sensor failing by becoming heat-sensitive, which is pretty common on all car brands.
Depending on what you have for equipment, there's two things I would do if this was happening to one of my vehicles. The first is to connect a scanner so I can view live data. I have a Chrysler DRB3 for most of my vehicles. Under the "Inputs / Outputs" menu, it lists the crankshaft position sensor and the camshaft position sensor as "Present" or "Lost". Aftermarket scanners may list them as "Yes" or "No", or something similar to indicate those signals are showing up at the computer. Those signals will both still be present when the engine stalls, as long as it's still rotating as it coasts to a stop. What you need to watch for is if one of them switches to "Lost" while you're driving, and then the engine stalls a fraction of a second later. That can be hard to catch, so most expensive scanners have a "record" function that lets you capture about a five-second picture of sensor data. Since that data passes through the scanner's memory, the recording actually starts a couple of seconds before you pressed the button.
Another thing to look at is the state of the ASD relay, meaning "on" or "off", and what happened at the instant it turned off. If it switched to "off" on the recording, and then engine speed started to drop, it was switched off by the computer, usually in response to losing the cam or crank sensor signal. Instead, if you see engine speed slowly dropping to "0', and then the ASD relay switched off a couple of seconds later, it was likely due to loss of spark or loss of fuel pressure, but not both. This is easier to see on a scanner because as long as the truck keeps coasting at a high enough speed, the transmission and torque converter will keep the engine rotating, perhaps as long a five to ten seconds.
You can also get a better idea if either of these tests seems appropriate by observing how the stalling occurs. A fuel pressure problem will cause sputtering or gradual loss of power over a period of a up to a few seconds. With a spark-related problem, or if the ASD relay turns off, stalling will be instant, as if you had switched the ignition switch off.
Jan 3, 2021 at 4:47 PM
96DODGERAM
  • 63 POSTS
Thank you for your reply. I haven't responded yet because it's hard for me to focus and read but I'm about halfway through. thank you for your patience.
Jan 4, 2021 at 4:42 PM
CARADIODOC
  • 34,306 POSTS
I'm here almost every day to impart my wondrous wisdom. I'll be back to see how you're doing.
Jan 4, 2021 at 5:04 PM
96DODGERAM
  • 63 POSTS
Darn dude those experiences you've had are crazy. Okay, so what I've gathered from your reply is that I need to hook it up to an obd2 and record until it shuts off and look for "lost" signals (I'll send the picture or video of the results). And also hook up a fuel gauge to see if it loses pressure when it shuts off. And also I'm almost positive my engine light bulb blew cause it never comes on and the fuse is fine and I looked how to replace it and that's definitely a project.
Jan 5, 2021 at 6:14 PM
CARADIODOC
  • 34,306 POSTS
Remember that there can be fault codes in the Engine Computer that don't turn on the Check Engine light, so we need to read those codes any time service is needed. Don't wait for the light to turn on.
Jan 5, 2021 at 7:04 PM
96DODGERAM
  • 63 POSTS
Okay, cool. I'll let you know when I hook it up might be a few days though.
Jan 5, 2021 at 7:15 PM
This guides can help you get the codes as well as the on, off trick. Also I have seen the crankshaft angle sensor cause this issue as well.
When the crank sensor goes out it may not leave a trouble code btw. Here is the sensor location. Check out the diagrams (below). Let us know what happens and please upload pictures or videos of the problem.
Jan 8, 2021 at 8:53 AM
96DODGERAM
  • 63 POSTS
I located the crankshaft sensor and it's in a really hard spot to get to and I don't have the right extensions to go at it from the top so I'm trying to figure out how to get to it. Sorry it took so long for me to reply if I start it up today I'll take a video and show everyone what it does. A buddy is also going to let me borrow his obd2 code reader today. I'll also send video of those results as well. thank you
Jan 13, 2021 at 9:03 AM
96DODGERAM
  • 63 POSTS
I had to drive last night and when I was driving I had my lights on and it acted like it shut off and my dash lights went a little dim so I pumped the gas to see if the truck actually did shut off and the lights got bright again and tried to stay on and it did that twice until I just pulled over because I had cars behind me and then it shut off. I just got the fuel injector connector so I can take them off and clean them and make sure none of them our clogged but maybe I'm wrong. Do you think I would have a spark problem or electrical problem from what I told you? it does backfire every once in a while when it shuts off and it doesn't want to start up. I usually give it about a minute to a minute and a half and then it starts right up but sometimes I get inpatient and try it too soon. My battery gauge on my truck stays the same doesn't drop at all until it shuts off.
Jan 13, 2021 at 9:16 AM
It almost sounds like the battery is shorting out, how dim do the light go? Can you please shoot a quick video with your phone so we can see what's going on? that would be great. You can upload it here with your response.
Jan 13, 2021 at 9:56 AM
96DODGERAM
  • 63 POSTS
It's a brand new battery and new terminals but the lights of to about 60%-70% bright. okay, I'll send one in about an hour or so.
Jan 13, 2021 at 9:59 AM
Its like the battery cables or the new battery is bad. Use this guide to test the battery:
Jan 14, 2021 at 8:18 AM
CARADIODOC
  • 34,306 POSTS
Sounds like the lights went dim because the engine was slowing to a stall. Cam and crank sensors that fail when they become heat-sensitive typically take at least a half hour to cool down and work again, and often up to an hour. Being able to restart after only a minute sounds exactly like the plugged strainer I described. Unfortunately I don't see that as being available separately as it was for me the four times this happened. The blue arrow is pointing to that strainer on the bottom of the fuel pump housing assembly. I've also found it is not available separately for my '94 Grand Voyager, but it was for my '88 Grand Caravan.
To add to the misery, many times this is diagnosed as a failing fuel pump, and replacements are usually available as just a pump and motor that get installed into the existing housing. Less-expensive replacement pumps might not come with a new strainer, but many do, then you're expected to pop the old one off and snap the new one onto the housing. If you do install that strainer, it's still assumed it was the pump that solved the problem.
Remember my comment too about nursing my van home by watching the fuel pressure gauge and momentarily lifting the accelerator pedal when pressure dropped to 20 psi. I was dragging a huge trailer at the time, but by keeping it going that way, anyone following me wouldn't even have known I was having a problem.
I suspect plugged injectors aren't the issue. That is not common, and it would not act the way you described. You'd have a lack of power under hard acceleration at first when they need to flow the largest volume of fuel, but it would have to get a lot worse to cause stalling, and then it wouldn't be intermittent, and the engine wouldn't be easy to restart at any time.
I'd suggest doing this first:
Fish the hose under the rear edge of the hood where it won't be cut. That way you can see what happens to fuel pressure when the problem occurs. You can find the gauge at any auto parts store that rents or borrows tools. In my city, they make you buy the tool, then you get a full refund when you take it back. If you choose to keep a tool, you still take that used one back, then they give or order you a brand new one.
Jan 14, 2021 at 5:29 PM
96DODGERAM
  • 63 POSTS
I'm sorry, it takes me so long to reply. I replace the fuel pump and it ran fine for about a day and a half and then back to the same. I bought a cheap obd2 from Walmart and it says no codes were detected and it only does a freeze frame when a code is set off, but this is what it does tell me:
Jan 31, 2021 at 4:36 PM
96DODGERAM
  • 63 POSTS
I have not been able to get to a fuel pressure gauge but I figured it would be good since I changed the pump.
Jan 31, 2021 at 4:39 PM
CARADIODOC
  • 34,306 POSTS
You've been describing symptoms very much like when the strainer in the fuel tank becomes plugged. When you replaced the fuel pump, if you replaced the complete housing assembly, you got a new strainer as part of it. Most people just get a pump and motor that has to be transplanted into the old housing. The more expensive ones come with a new strainer that has to be snapped on separately, but they can't be replaced separately on some models. This is where you need the fuel pressure gauge to see what's going on. If the strainer is plugged, you'll see fuel pressure slowly drop until stalling occurs. It will pass fuel again after sitting for a few minutes. Stalling is also more likely to occur when the highest volume of fuel is being pumped, which is during coasting.
Jan 31, 2021 at 5:18 PM
96DODGERAM
  • 63 POSTS
This is the one I got and took it to the mechanic he changed it all said he test drove it for a few on his drive he shut it off turned it on 3 or 4 times then headed back to the shop and like I said when I got it back I drove all over town no problem til the next day but I feel like it does do what you just said but it also dies when I let it idle to long and I cleaned the idle air control sensor which helped it out alot I cleaned the fuel injectors today thought maybe 1 was clogged but it shut off after about 30 minutes of idling and it came right back on left it on until it shut off after about 20 minutes then wouldn't turn back on so I went back inside.
Jan 31, 2021 at 5:50 PM
CARADIODOC
  • 34,306 POSTS
Dandy. That's the complete assembly including the strainer at the bottom. I did have a second strainer become plugged on my '88 Grand Caravan, but that was after another 200,000 miles.
I haven't run into this for quite a while, but repeat fuel pump failures used to be not uncommon. You'd buy an aftermarket pump, stick it in, then it would fail after a week or two. Get it replaced under warranty, and it too would fail after a couple of weeks. Try one from a different auto parts store, and it also failed after two weeks. By the time you got frustrated after the fourth or fifth pump, you'd buy one from the dealer and have no more problems.
The cause actually had nothing to do with where the pumps were coming from. In fact, Napa gets their Chrysler pumps from the same supplier that sells them to Chrysler. What was happening was microscopic debris had collected in the tank, and that was plugging the impellers in the pumps. It was just coincidence that by the time you bought the one from the dealer, all that debris had been collected and was no longer in the tank.
This was common enough that a service bulletin was issued telling us to have the tank steam-cleaned at a radiator repair shop any time the fuel pump had to be replaced. That did indeed stop the repeat failures.
After discussing this with a friend who runs a small engine repair shop, he showed me a sample of how mold grows in the ethanol in today's gas. I have to wonder if that contributed to the fuel pump problem.
We've also found that GM and Chrysler fuel pumps almost always fail in different ways. GM pumps slow down or lock up after you've been driving a while, leaving you sitting on the side of the road. They're also relatively noisy and easy to hear running, especially on their trucks. It is extremely rare for a Chrysler fuel pump to stop running once it has started up. They are built to tighter tolerances which makes them real quiet, but more prone to locking up from debris. Their pumps fail from worn brushes in the motor. That causes them to fail to start up, leaving you sitting in the parking lot or driveway. If they do start up, or if you get them going by banging on the gas tank, they'll keep running until you stop the engine.
Feb 1, 2021 at 10:53 AM
96DODGERAM
  • 63 POSTS
So your saying my gas tank could be dirty? I did put a fuel treatment in it and a full tank of gas a little while back but I don't get to drive my truck that much seeing how I don't want to drive a few blocks and stop driving a few more blocks and stop. I really doubt this but say the fuel pump was the right problem. do you think the computer is just getting used to the new pump? I saw a video of a guy saying current parts when you get them changed it takes the computer a few trips to get it to reset until the computer corrects itself and starts working like it should.
Feb 1, 2021 at 5:19 PM
CARADIODOC
  • 34,306 POSTS
That relearning applies to sensors because no two are ever exactly alike. The process usually takes just a few seconds, and you'll rarely notice any performance issues.
As for the fuel pump, those take a lot of current so they're always turned on and off through a relay. The low-current coil side of the relay is the only part the computer sees, and that is the same for any replacement relay. As for the contact side, the computer has no idea of how much current is flowing or whether it's excessive or too low. It doesn't even know what is being powered up.
The only other variables related to the fuel pump are pressure and volume, but even those are irrelevant. The pumps can develop as much as 70 psi if the fuel line is blocked. During normal operation that fuel passes through a spring-loaded pressure regulator valve on the fuel rail on the engine. That holds pressure down to around 45 to 50 psi, and that changes a little from changes in manifold vacuum. That's why there's a vacuum hose plugged into the regulator. When you're coasting, vacuum goes way up, and that being one of the two forces acting on a molecule of gas, would pull the gas from the tip of the injector into the engine too aggressively leading to a very rich coasting condition. By tying it to manifold vacuum, that tugs on the spring-loaded valve so it opens easier, thereby lowering fuel pressure. Higher pulling force coupled with reduced pushing force equals a steady fuel flow that prevents that rich coasting condition. As long as the pumps can maintain a pressure higher than the regulator is set at, every replacement pump will develop the same pressure in the line, so there's nothing to learn there.
The other issue is pump volume. This is another big area of confusion and is directly related to that stalling due to the plugged screen I described. Every pump is going to move a good one or two gallons per minute. That is what has to get through the strainer. Way less than one percent of that gets diverted to go through the injectors into the engine. Well over 99 percent goes through the pressure regulator, then back into the tank through the smaller-diameter return line. The strainer can be plugged enough to drop fuel volume to the point that only enough gets through to meet the needs of the engine. That leaves nothing to go back through the regulator and return line. If the blockage gets just a little worse, fuel volume becomes less than what the engine needs, then you have hesitations, stumbling, or stalling.
To finish my story on the strainer, when you're coasting and manifold vacuum goes up real high, the fuel pressure regulator drops pressure so the total of the two forces acting on the fuel remains steady. Dropping pressure means the fuel finds it easier to flow through the regulator, and that is what makes volume go real high. When the strainer is plugged, the volume isn't high enough. That results in the symptom of stalling due to fuel starvation when coasting, and the engine runs better when accelerating or cruising, which is when it burns more fuel. The confusion comes from the volume of fuel being pumped, or circulated, and the volume of fuel going into the engine are opposite. One goes up when the other goes down.
So now let me answer your question a better way. The computer doesn't learn anything related to the fuel pump. As long as there's plenty of fuel volume, and the correct fuel pressure, the only things that affect that are the fuel pressure regulator and the strainer.
Feb 2, 2021 at 9:41 AM
96DODGERAM
  • 63 POSTS
Thank you for your reply. here's a picture of the list of everything I have done to it:
Feb 2, 2021 at 10:15 AM
CARADIODOC
  • 34,306 POSTS
Chrysler is the only manufacturer back then that never used a mass air flow sensor or needed them to make their engines run right. That was something else you cleaned.
I know you're listing everything you've done, even those things not related to this problem. Keep in mind things like spark plugs don't all stop working at the same time, so a lot of similar parts will not be good suspects. Also, while this has nothing to do with stalling, the goal of the intake system is to warm the air so gas will vaporize easier. Liquid gas doesn't burn. It has to be in vapor form. Cold air intakes make that less effective.
In looking back, unless I missed it, I didn't describe how most scanners have a "record" feature. That, along with the fuel pressure gauge, is what we need to solve this. You drive around with the scanner connected, then, when the stalling occurs, you press the "record" switch on the scanner. Because the data travels through the scanner's memory, the recording actually begins a couple of seconds before you pressed the switch. Later that few seconds of data can be played back slowly to see what changed. For the stalling, we'd watch the crankshaft position sensor and the camshaft position sensor to see if either signal dropped out. Both are needed for the Engine Computer to keep the automatic shutdown, (ASD) relay turned on. That relay sends current to the ignition coil(s), injectors, and fuel pump or pump relay.
If one of those sensors is responsible, you'll also see the "ASD Request" switch to "off", and the listed engine speed will drop instantly to "0". If this is a fuel-related problem, engine speed will gradually drop down until stalling occurs. While coasting to a stop, the transmission will keep the engine rotating down to around 20 - 30 mph, and since this isn't a sensor problem, engine speed will continue to show up as it slows down gradually. Of course if this is fuel-related, that would also show up on the fuel pressure gauge.
Feb 2, 2021 at 5:56 PM
96DODGERAM
  • 63 POSTS
I'll be getting a fuel gauge pretty soon and I need to take my obd2 scanner back to upgrade it because I got the little cheap 1 from Walmart. I thought it would have a record or live data feature but it only has a freeze frame but only when a code is detected. I normally get o2 sensor codes because I don't have an upstream o2 sensor, but everyone I've talked to says that wouldn't be the problem.
Feb 2, 2021 at 6:20 PM
96DODGERAM
  • 63 POSTS
Well, I'm taking it to get a full diagnosis Wednesday or Thursday. I was looking up videos and parts and realized that I'm pretty sure the previous owner changed the ignition because the key is not an original and doesn't go to any doors. Do you think they could have put it wrong maybe? Because I read that when your ignition switch is going bad it could stall the motor or shut it off also.
Feb 7, 2021 at 6:01 PM
CARADIODOC
  • 34,306 POSTS
There was a common problem with the ignition switches in some models, but that never caused stalling. There's three or four parts to that switch. One of them developed overheated contacts or an overheated pair of connector terminals, and either one would lead to the other. That was for the high-current accessory circuit to include the power windows, radio, and heater fan motor. The problem occurred most often to owners who usually switch the ignition switch on and off while the heater fan is set to one of the higher speeds. That results in heavy arcing on those contacts, and that leads to them overheating.
The ignition switch and lock cylinder are replaced separately, so a failure of one doesn't mean the other one had to be replaced.
Feb 7, 2021 at 6:27 PM
96DODGERAM
  • 63 POSTS
Okay, I bought a cheap tachometer to put in it so I can see my RPMs and that's when I seen it said that so I started looking up ignition switch info, lol.
Feb 7, 2021 at 6:32 PM
96DODGERAM
  • 63 POSTS
I got my truck back from the mechanic they tried running a diagnosis test with all their equipment and they couldn't figure out the problem. His computer said that there was some type of voltage reading and he said vehicles are supposed to be between 1-5 and mine was at 6. I'm not sure what he was talking about but he said he changed the crankshaft sensor and the camshaft sensor and it still read the same thing. When I start it in the morning sometimes it will die after about 10 seconds and then start back up and good to go. I drove around town the other day and it died on me once in about a 30-40 minute drive but started back up and was good after that. It's not 100% fixed but I can deal with it as it sits it is definitely way better than it was. I'm just giving you guys an update on where I'm sitting with it. Thank you guys for all your help.
Feb 27, 2021 at 4:17 PM
CARADIODOC
  • 34,306 POSTS
My guess is the "1-5" he was referring to had to do with the throttle position sensor or the MAP sensor. Those are fed with 5.0 volts and 0 volts, (ground), then they develop a signal voltage between 0.5 and 4.5 volts. Those are the voltages we use for training and explanation purposes. In real life, you might find 0.42 and 4.71 volts. The point is they can't reach 0 or 5.0 volts. The TPS has mechanical stops to limit its range to 0.5 to 4.5 volts, and the MAP sensor has circuitry that will do the same thing.
It's when there is a defect inside the sensor or with its wiring that a signal voltage can make it to 0.0 or 5.0 volts, and the computer sees that and sets a diagnostic fault code in response. In fact, it's those voltages that are what the computer looks at when testing the circuits. Temperature sensor circuits work a little differently, but the same range of voltages apply.
Remember, if your mechanic did any type of testing with electronic equipment, that didn't include fuel pressure and volume, so he wouldn't have seen a problem there. Please keep me updated of any developments.
Mar 1, 2021 at 8:26 AM
96DODGERAM
  • 63 POSTS
He thinks I have a bad ECM, but he's not 100% sure that's it he wants to get 1 for cheap or me buy 1 and hook it up to see if that's the issue. but I can't find 1 for less than $200.00. if that's not the problem I'd be pretty pissed just like I get everytime I spend money for no reason on parts that probably aren't even bad on this truck.
Mar 3, 2021 at 10:05 AM
CARADIODOC
  • 34,306 POSTS
There's too much confusion to know where to go next. Your mechanic gave you some numbers, but we don't know what they refer to, so we don't even know if those have anything to do with something that could cause stalling. I haven't seen any fuel pressure test results, so we don't know if we have to look at the fuel supply system or move on to other systems. You have a new fuel pump with strainer, but there's also wiring that can have a corroded splice or connector terminal that causes intermittent operation. We would only see that on the fuel pressure gauge as fuel pressure isn't monitored by the Engine Computer.
Just about every repair shop has a scanner with a "record" feature that will record a few seconds of data that can be read back slowly, later, to see what changed when the problem occurred. That hasn't been done either. You can see why this is like asking your doctor for a diagnosis, but he hasn't run any tests yet. Engine Computers do fail from time to time, but in general, that's the first thing people think of, but usually the least likely item to solve a running problem. If you want to substitute the computer, there's nothing to program for a '96 model. I'd head to a pick-your-own-parts salvage yard to find an inexpensive replacement to try. Do a search for "Pull-A-Part" to see if they have a yard near you. They have about two dozen yards, mostly between Ohio and Georgia, but now also a few to the southwest. Their yards are extremely clean and well organized, employees and customers have always been very friendly and helpful, and parts are inexpensive. There's more and more yards like these popping up all over, but none are as clean and well-organized.
I should point out too that if you replace the Engine Computer, which obviously means unplugging it, or if you disconnect the battery, the computer will lose its memory. Most of the learned data will be rebuilt as soon as you start driving, without you even noticing, except for "minimum throttle". Until that is learned, you may have to hold the accelerator pedal down 1/4" for the engine to start and stay running. You won't get the normal idle flare-up to 1500 rpm for a few seconds after start-up, and it will tend to stall at stop signs. To meet the conditions for that relearn to take place, go out and drive it at highway speed, (with two feet if necessary), then with the engine warmed up, coast for at least seven seconds without touching the pedals. The computer will again be in control of idle speed at the end of that seven seconds.
Mar 3, 2021 at 3:24 PM
96DODGERAM
  • 63 POSTS
When I get paid again I'm getting a fuel pressure gauge kit from Napa for $40.00. I have a scan tool that shows live data I just got it the next time it starts acting up (if I'm not going to work) I'll take a video of the live data and I'll try to get a video of when it's running good same with the fuel pressure gauge. I hope it's not the ECM but like I said the mechanic I took it to isn't even for sure that's what's messed up he just wants to see if it's that. I'm trying to kind of steer away from that for now especially you saying it's got to get its memory back, lol.
Mar 4, 2021 at 8:03 PM
I noticed it's been a few days. Have you made any progress with the issue? We are very interested in knowing.
Thanks and God Bless,
Mar 8, 2021 at 7:21 PM
96DODGERAM
  • 63 POSTS
No progress yet other than what you've read. I'm waiting to get paid and then I'm going to get a fuel pressure gauge to check it. It's weird 1 day it's hard to start and give me problems and the next day all good starts right up and won't shut off and then back to being cranky.
Mar 8, 2021 at 7:36 PM
96DODGERAM
  • 63 POSTS
Here's the readings I got on my obd2:
Mar 9, 2021 at 9:29 AM
I looked at your pics. The short-term fuel trims are indicating fuel being added. Have you checked for vacuum leaks or the fuel pressure? Also, the coolant temperature sensor says 95°F. Was this done as soon as the vehicle was started and still not at operating temperature?
Mar 9, 2021 at 5:16 PM
96DODGERAM
  • 63 POSTS
Yes, it was it was hard to start so I hooked it up and then took the pictures like 5 after it was idling. I don't know how to check vacuum leaks and I need to get paid before I can get a fuel pressure gauge and then I can send that info.
Mar 9, 2021 at 5:32 PM
If it was running for five minutes, the ECT should have been higher. I'm starting to question if that is the issue.
Do me a favor. Allow the engine to reach operating temperature. See what the ECT signal is at that point. It should be around 200°f.
Also, here is a link that explains how to check for a vacuum leak:
Let me know what you find.
Mar 9, 2021 at 5:39 PM
96DODGERAM
  • 63 POSTS
Okay, I'll do that and I do know that when it's warmed up it stays around 180-200 f.
Mar 9, 2021 at 5:44 PM
