[quote:a74c20bf06="rasmataz"]Hi blustrat6, Welcome to 2carpros and TY for the donation
When was your last oil change and filter? could also be a leakdown problem with the lifters
Engine - Noise/Damage Oil Filter Application Importance
Notes
TBS's INFORMATION
Bulletin No.: 07-06-01-016B
Date: July 27, 2009
Subject: Information on Internal Engine Noise or Damage After Oil Filter Replacement
Models:
2010 and Prior Passenger Cars and Trucks (Including Saturn)
2010 and Prior HUMMER H2, H3
2009 and Prior Saab 9-7X
Supercede:
This bulletin is being updated to add model years. Please discard Corporate Bulletin Number 07-06-01-016A (Section 06 - Engine/Propulsion System).
Important
Engine damage that is the result of an incorrect or improperly installed engine oil filter is not a warrantable claim. The best way to avoid oil filter quality concerns is to purchase ACDelco(R) oil filters directly from GMSPO.
Oil filter misapplication may cause abnormal engine noise or internal damage. Always utilize the most recent parts information to ensure the correct part number filter is installed when replacing oil filters. Do not rely on physical dimensions alone. Counterfeit copies of name brand parts have been discovered in some aftermarket parts systems. Always ensure the parts you install are from a trusted source. Improper oil filter installation may result in catastrophic engine damage.
Refer to the appropriate Service Information (SI) installation instructions when replacing any oil filter and pay particular attention to procedures for proper cartridge filter element alignment. If the diagnostics in SI (Engine Mechanical) lead to the oil filter as the cause of the internal engine noise or damage, dealers should submit a field product report. Refer to Corporate Bulletin Number 02-00-89-002I (Information for Dealers on How to Submit a Field Product Report).[/quote:a74c20bf06] Sir I installed a new GM filter but the noise is still there. Will the lifters eventually pump back or is the damage to top end permenant..I only ran engine for a few minutes. Have you experienced any sucess after new filter, is there any chance for this 2.2?
Mar 12, 2010 at 8:49 PM
