WE ARE NOW GONNA "BYPASS" THE IGNITION SYSTEM
............THIS WILL TELL US IF IT WILL RUN......AND WILL TELL US IF IT'S IN THE WIRING (OR COMPONENTS ALONG THE WAY)
SO.........IF ALL THE OTHER STUFF UNDER THE HOOD IS OK.....THIS WILL MAKE IT RUN
...........HOWEVER, TO MAKE IT STOP, YOU WILL HAVE TO DISCONNECT THE JUMPER AT THE BATTERY
YOU WILL STILL TURN THE KEY TO MAKE IT TURN OVER!
DO PIC 1
THE FUSE IN MY JUMPER IS "SHORT PROTECTION"........I LIKE TO PLAY IT SAFE!
THE REASON I COMPLETELY REMOVE THE COIL CAP IS TO GET RID OF ANY PROBLEM BACK TOWARDS THE KEY
WE WILL BE RUNNING OFF OF THE BATTERY/ COIL/ DISTRIBUTOR/ AND IGNITION MODULE (IF IT IS GOOD-IF IT GETS IT'S OWN POWER)
DON'T FRET IF THIS DON'T WORK----I CAN KEEP DIAGNOSING FOREVER!
LET'S TRY THIS IF WE DON'T HAVE POSITIVE RESULTS WITH THE IGNITION BYPASS
...............................OFF TO A POPULAR AUTO PARTS STORE, YOU GO....THEY USUALLY WILL TEST THESE FOR FREE
LETS WATCH AND SEE IF THEY HOOK UP RIGHT (IF YOU KINDA CAN READ THE CHART THEY ARE READING)
THEN HAVE THEM TEST IT 5-8 TIMES (THIS WILL WARM IT UP) SHOULD IT FAIL THE LAST FEW TESTS.....('COURSE THEY'LL SAY ONE TIME IS FINE....IT'S NOT!!!!)....AND YOU MIGHT SUFFER...NOT THEM!......SO MAKE 'EM DO IT!
WHAT IF IT FAILS?.............YES, REPLACE IT!
AS YOU PUT YOU HAND ON THEIR DOOR HANDLE TO LEAVE, WITH YOUR NEW ONE............
TURN YOUR BUTT RIGHT AROUND, GO BACK TO THE COUNTER, AND HAVE THEM TEST "THEIR" NEW ONE 5-8 TIMES.
WHY????
THERE'S NOTHING LIKE TEARING YOUR ENTIRE JEEP CJ 5 DOWN (EVEN THE WIRING) FOR 2 DAYS, TEARING YOUR HAIR OUT!.........BECAUSE, IT WILL NOT START!!! .......THEN YOU TAKE THE BRAND NEW, UNTESTED MODULE, BACK TO THE STORE, ONLY TO FIND OUT.....IT TOO, WAS BAD!......................................BEEN THERE, DONE THAT......ONLY ONCE!
BELOW IS A PIC OF THE TESTER AT ADVANCE AUTO......THE CORRECT PIG-TAIL(S) TO TEST YOURS IS RIGHT BESIDE THE MACHINE (I PUT THEM THERE!)
PIC 1) TEST THIS WAY
PICS 2 AND 3) THIS WAY LEAVES THE WIRES TO THE IGNITION SWITCH "IN" THE EQUATION....IF THERE IS A DEAD SHORT ALONG THE WAY.....IT'LL GROUND OUT OUR BYPASS ATTEMPT TOO....SO DO IT THE OTHER WAY (PIC 1).............................DOING IT THIS WAY (PICS 2 AND 3) YOU SHOULD BE USING THE FUSE IN THE JUMPER, FOR SURE!
PICS 4 AND 5) THIS IS THE MODULE TESTER AT ADVANCE AUTO PARTS........IS THIS A STORE NEAR YOU?
PIC 6) SOME OF MY CJ MANUALS
SEE THIS LINK........"A124" WAS WORKING TODAY!.......I HAVE NO CLUE WHEN IT WILL EXPIRE, IT'S WORKED FOR QUITE SOME TIME NOW!
https://www.2carpros.com/questions/2001-dodge-neon-milage-just-want-put-fliuds-their-locations
SORRY IT TOOK ME SO LONG.....IT'S 23:50 HRS EST RIGHT NOW....I'VE BEEN BUSY ALL DAY........I ALWAYS TAKE CARE OF THE JEEP GUYS (ONE'S WITH A FOLD DOWN WINDSHIELD ANYWAY).....DON'T THINK I'M ABANDONING YOU!
REMEMBER....I'M ATTEMPTING TO TRANSLATE "CJ" INTO "WRANGLER" THE BEST I CAN
AS YOU CAN SEE, I HAVE MEGA HOME-MADE PICS AND LITERATURE
THE MEDIC
Jul 10, 2013 at 9:11 PM
