Engine not running?
1995 PLYMOUTH ACCLAIM
189,000 MILES • 6 CYL • FWD • AUTOMATIC
JOHNNYT73
  • 924 POSTS
could also be a crank position sensor.
Jul 24, 2020 at 6:11 PM (Merged)
DLS5785
while driving at 55 mph my car started to decrease in mph and then the care eventually stopped running. I tried to start it up again and then it only ran for about 30 seconds and stalled again. I replaced the fuel filter at the suggestion of a friend. Tried starting the car and again it only ran for about 30 seconds. I replaed the fuel pump in this car about 4-5 years ago and was wondering if it could be the fuel pump again. I don't want to replace it if that is not the problem, as I don't want to spend money on something that is not needed. I know some car can have a diagnostic test and was wondering if my car has the connection so that a diagnostic test can be done on my car. Thank you for your help
JDL
  • 16,098 POSTS
Welcome to the forum. If there are any codes, cycle the ignition switch to on, three times, on--off, on--off, on, then the check engine lite starts flashing, you count the flashes to get the codes. If your talking about using a scanner, there should be a connector under the hood, don't have exact location in front of me, I have seen them near the battery. I'd use a gage and check fuel pressure, before suspecting the pump.
KLEVER22
  • 4 POSTS
1993 Plymouth Acclaim 4 cyl Front Wheel Drive Automatic
Hello! I am looking for help with my 1993 plymouth acclaim. When the key is turned she cranks but won't start without adding starting fluid. Even then she only runs until the fluid is burned up. The fuel pump, fuel filter, and fuel injector have all been replaced. The fuel makes it to the injector but is not injected, and the pressure is good up to the injector. I tested the wiring from the computer to the injector and at the injector and it works fine. I have checked the wire going to the auto-shutdown relay from the injector and it is good as well. One of the relay's wires is hot when the car is off even though that particular wire isn't supposed to be, it then gets even more electricity going through it when it cranking. I suspect either the auto-shutdown relay or a ground wire, but I'm not sure. Last august the car had been running fine (aside from needing the transmission oil changed and the knockdown(?) bolts tightened) I parked her, turned her off, and she didn't start again. A few months ago before I replaced the fuel pump she fired up once, not sure why, then when turned off she wouldn't start again.
Any help or suggestions you can give me would be great.
Thanks!
Jul 24, 2020 at 6:12 PM (Merged)
MERLIN2021
  • 17,250 POSTS
Start here, and we'll go from there!:
Is your check engine light on? If yes turn the key from off to on three times, on the fourth one leave it in the on position, count the flasshes...22 would flash as 2 blinks, then a short puase, then 2 more blinks...if several codes are stored, the pause is longer between codes, code 55 will be the last code...do this and post all codes found... Could be a no crank reference problem, but check codes please!
KLEVER22
  • 4 POSTS
The only codes I get off of her is the one that says the battery was disconnected within the last 50 cycles, which it has been.
MERLIN2021
  • 17,250 POSTS
Remove the ASD relay and check if the wire is still hot, if not try replacing/testing the relay.
KLEVER22
  • 4 POSTS
I have replaced the ASD relay and disconnected the negative battery cable for about 40 minutes, reattached it and tried again. I got the same result as before.
MERLIN2021
  • 17,250 POSTS
Get an analog voltmeter remove the negative battery cable, attach the Black lead to the battery post, Red lead to cable end, then pull fuses one at a time, make sure there are no accessories or lights in the on position, Key off! Close the door after each fuse and check meter, when you pull the fuse for the bad curcuit, the meter will drop to 1 volt or so. Check all fuses, even under the hood. If meter does not drop, remove the battery connection from the alternator, if it drops now, the diodes are bad in the alternator. Put the fuse back in were it goes as you go so you don't forget which fuse goes were! This will track down which circuit needs to be checked, You may need to remove the relay center the ASD is in and inspect the wires under it.
RECON134
My car stalled when I was driving, I tried to restart by putting car in neutral, but no luck I noticed the check engine light was flashing but I was unaware of the codes at that time. I parked the car and turned on my flashers, but by the time I could get back to my car the battery was dead. I towed car home and charged the battery, and turned the key on and off 3-4 times but the computer was clean this time and I got a solied light. I have changed the ASD Relay, but the engine turns over freely as before but will not start. Any ideas?
KLEVER22
  • 4 POSTS
I checked the fuses, relays (both under the hood and next to the fuse box) and the battery connection to the alternator. All of them look good.
CARADIODOC
  • 34,306 POSTS
First check for spark before you randomly replace parts. If spark is missing, check if the ASD relay is turning on. Measure the voltage at the positive terminal on the ignition coil or either small terminal on the back of the alternator. A test light is more accurate here than a voltmeter because most digital meters don't respond fast enough. You'll see 12 volts for one second after turning on the ignition switch. What's important is if it comes back during engine cranking. If it does not, suspect the Hall Effect pickup assembly under the rotor in the distributor. Before you replace it, be sure the rotor is turning during cranking. If it isn't, the timing belt is broken.
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
Just curious, have you tested and inspected closely the wiring harness for the fuel injectors themselves?
MIKE1014
  • 4 POSTS
Computer problem
1993 Plymouth Acclaim 4 cyl Front Wheel Drive Automatic 100k miles
no spark feul pump doesn't run changed hall effect sensor and PCM book says I should get 9 volts to hall effect sensor but I only get 2.8 volts if you don't get a signal from the hall effect sensor theres a relay called the automatic shut down relay shuts off fuel pump and 12 volt going to the coil It seem like the PCM is bad or something is draging down the voltage to the hall effect sensor the books I have don't have enough info I checked for shorts and the wiring from the sensor to the Pcm is good
At the injector dark green and orange wire check for power-do you have it?
MIKE1014
  • 4 POSTS
No, there isn't any power to the orange and green wires.
Test the ASD relay and fuse no.11 10amp. If okay have the computer tested. The ASD relay powers the coil/injector/fuel pump
MIKE1014
  • 4 POSTS
ASD relay was replaced
GRASSIER
Hey Guys,
I have been trouble shooting my Acclaim for the past three days. Here is what I have found:
Engine will crank but not start. Engine has good spark, compression and air.
I thought at first it was the fuel pump because the car would start right away when I spray quick start into throttle body and if you keep spraying it, it will continue to run. But I checked the fuel pump and it has good pressure. Fuel Filter is new and is not the problem because I checked the fuel pressure right up until it goes into the throttle body.
So I was thinking either the Fuel Regulator or the injectors? or is there some sort of EFI module that could be bad?
I had driven the car the day before and everything was running fine. When I went to start the car in the morning for work (much milder day than usual) it almost started on first key turn and then would not start...hasnt since.
Another thing I noticed is that when the engine is cranking a tiny bit of fuel is dripping out of the module that is directly over the hole in the throttle body. I am thinking this is some type of secondary injector? Maybe when the throttle is wide open? But it is not enough fuel dripping to start the engine. I have to spray quick start to get it to turn over. Not sure if this means anything or not but thought I would mention it.
Please let me know what I should check next as I really need to get this bad boy back on the road.
Really appreciate your help!
Cheers, RG
2CARPRO JACK
  • 11,533 POSTS
Chryslers use an Auto Shut Down Relay or ASD. this could very well be the problem.First get a test light and check for power to one side of the injector harness. The fuel is dripping from the fuel pressure regulator, it needs to be replaced or it will run rich
MIKE1014
  • 4 POSTS
relpaced asd relay no fuses, fusable links don't know if I should get contenuity between green and orange wire beteen relay and injector
GRASSIER
Well I actually already tested the ASD relay and it was fine. Plus it also controls the fuel pump and it is working fine while the car is cranking. The fuel makes it all the way to the throttle body but never seems to get injected into the engine. Could it be just the fuel regulator? I just didnt think the fuel regulator would just quit all of a sudden like that? figured it must be something computer or electrical.
What else can I try?
2CARPRO JACK
  • 11,533 POSTS
You need to check for pulse at the injector, that is why I asked you to check for power at the injector plug. If you have a "noid" light see if it flashes when cranking
GRASSIER
OK I will check tonight and report back! Thanks!
TIMOTHYJSAUNDERS
I recently arced the positive terminal of the battery to the hood and blew 2 fusible links. \i repaired them and the car won't start. I was told the ecm was bad so i changed it and still nothing. The car turns over and starts for a second then shuts off. It turns over after that but thats it. When I turn the key on i only get a 9V reading on the volt gauge but the battery is brand new. I have also tried replacing the coil and still nothing. What else could it be?
CARADIODOC
  • 34,306 POSTS
Lets start with the basics. Which engine do you have?
Measure the voltage at the coil's positive terminal. You should see 12 volts for one second after turning on the ignition switch, then it should come back during cranking.
KATHYLOWERY
  • 4 POSTS
92 plymouth acclaim 2.5 wont start getting weak spark replaced roter cap coil fuel pump working and plugs ready to pull hair out
DOCDTC
  • 53 POSTS
Kathy,
When is the last time the timing belt was replaced? Have you done any testing of the hall-effect pick-up assembly in the dist? Is/Was the check engine light prior to the no-start condition? And finally, have you checked to see if you are getting injector pulse? with a little more info, I think we can save your hair. Let me know, Doc
KATHYLOWERY
  • 4 POSTS
car was running great just stopped all of the sudden and would not start timing belt good timing good also
CARADIODOC
  • 34,306 POSTS
If you have weak but consistent spark, suspect the ignition coil. Everything that triggers it is working.
Jul 24, 2020 at 6:13 PM (Merged)
DOCDTC
  • 53 POSTS
Have you checked for inj. pulse? Injectors are driven by the ASD relay(B+) and switched on the ground side. Check for power on the Dk.Grn-Org wire at the fuel injector. if you have power there, Next hook the clamp end of your test light to B+ and probe the other side while cranking. the light should flash.
JAPPYAPPLERED
92 Acclaim ran great until parked for a few months without being started. Battery was dead & could not be jumped. I had an old battery from my honda civic that still had %80 charge, so I threw it in hoping it would start. The car sounds like it has plenty of power & cranks real fast, but will not start. My question is, is it possible I just need the right battery & it will start? I don't want to buy a new one if it doesnt fix the problem. Any help would be great!
BMRFIXIT
  • 19,053 POSTS
The battery's job is to spin the engine and what you have is cranking the engine just fine I would:
check the timing belt
check for fuel and spark
let me know what is missing
KATHYLOWERY
  • 4 POSTS
i have even pored small amount of fuel into carb/injector and could not get results
JAPPYAPPLERED
Aparently the timing belt, distributor cap & rotor, plugs & wires were already replaced. Perhaps the plugs are foulded? But would this happen just from sitting? The car is at a friends house out of town so I haven't had access to it for a few days.
What are the chances of a fuel pump going bad from the car just sitting? I'n my honda I can always hear the fuel pump prime when I turn the key, but I heard nothing with the Acclaim.
KATHYLOWERY
  • 4 POSTS
i have replaced plugs coil wires distcap distbutton part under button torn front of motor apart and check timing belt for quality and position all appears good
BMRFIXIT
  • 19,053 POSTS
I would check ........
check for spark and check for fuel
go to the tank and hit it while a helper tries starting the engine
92ACCLAIM
i bought this car used 2 weeks ago, the person who sold it to me had it for sale sitting for a year in the half. i drove it back to my garage, changed all the fluids and everything. started the car like 8 times until it stopped cranking. When i turn the key to start, there is a click coming from the starter relay and when i release the key from start to on it clicks once more. i replaced the starter cause i thought that initially was the problem. got the battery load tested, it was good, charged the battery too. there are two wires that go to the starter solenoid, Red wire (always hot) and the S terminal brown wire which is only hot when trying to crank. i light tested the red wire and it was bright and looked great. however when i test light the S terminal wire, the light was a dim light when i turned the key to see if its getting proper voltage. i never seen a test light test shine "dim". checked all terminals and ground to make sure free of corrosion. In addition, i can start the car by taking a flat head by touching the solenoids red wire nut to the S terminal and it starts right away! so im stuck and have no idea what to do...im getting extremely inpatient however im keeping cool. please help
First of all, great job. You checked about everything I would have told you to. However, have you check the starter relay? Try switching it with another one that has the same part number and see if that helps. Also, check the voltage to the relay if the new relay doesn't work.
JOEDOLLARHIDE
Why won't my car start I just drove it this morning and it has power. The starter is good. It sounds like is trying to it just won't actually start.
