Engine Overheating?
2001 CHEVROLET VENTURE
80,000 MILES • 3.4L • 6 CYL • AUTOMATIC
EARL.OWENS
yes, I checked all the pullys on it and everthing is tight and nothing is broken or loose
Aug 21, 2020 at 11:51 AM (Merged)
SATURNTECH9
  • 30,869 POSTS
See if the belt tenisoner has plenty of tension?Also if all the pulleys are lined up with each other?
HRALI6
Chevrolet venture 2000 overheat when stop cooldown when it run otherwords idling overheat run the gage go to cooldown ???????
FIXITMR
  • 9,990 POSTS
is cooling radiator fan working when hot?
Check the thermostat, coolant level and cooling fan
