My '95 F-150 5.8l occasionally will not start and engine will stall when driving. when this happens there is no spark from the ignition coil. I can sit there and try to start the truck form 10 min. to an hour and it will eventually start. This happens when the truck has been sitting for awhile.
Recently when it happened the engine was sitting for 14 hrs. When I tried to start the engine sounded like it was going to start but it was weak. I checked for spark and it was very weak then went away. After trying for 30 min. it started.
I have replaced the ignition coil and ignition control module. I took it to an auto shop a month a go and they said it was a bad wire between ICM and distributor. It was fine for awhile but problem returned. I took it back, they had it for 4 days and told me they got it to act up one but not long enough to use a scoop on it. They basically said it could be a number of things, pick up coil, ignition switch, bad wire some where, and good luck to you. Funny thing is when I got the truck back the second time I tried to start it, it exibited the problem, in fact it did it twice in the same day. Please help!
Apr 26, 2021 at 1:19 PM
(Merged)
