The ECM or PCM determines which ignition coil should be controlled by means of the signals from the camshaft position sensor which is incorporated in the camshaft and from the crankshaft position sensor which is incorporated in the crankshaft. It also detects the crankshaft position to provide ignition at the most appropriate timing in response to the engine operation conditions.
What I would start with is simply checking to make sure you are getting signals from both sensors I mentioned. If you have an oscilloscope, here are the directions for testing the cam sensor and crank sensor. The attached pics correlate with the directions.
_________________________
2007 Mitsubishi Eclipse L4-2.4L (4G69)
Oscilloscope Patterns and Wave-forms
Vehicle Power-train Management Sensors and Switches - Power-train Management Sensors and Switches - Computers and Control Systems Camshaft Position Sensor Testing and Inspection Oscilloscope Patterns and Wave-forms
OSCILLOSCOPE PATTERNS AND WAVE-FORMS
INSPECTION PROCEDURE USING AN OSCILLOSCOPE
CAMSHAFT POSITION SENSOR
pic 1
Required Special Tools:
- MB991709: Test Harness
- MB991658: Test Harness
- MB991923: Power Plant ECU Check Harness
Measurement Method
1. Disconnect the camshaft position sensor connector, and connect the test harness special tool (MB991709) between the separated connector (All terminals should be connected)
2. Connect the oscilloscope probe to camshaft position sensor connector terminal No. 2.
pic 2
3. Disconnect the crankshaft position sensor intermediate connector, and connect the test harness special tool (MB991658) between the separated connector.
4. Connect the oscilloscope probe to crankshaft position sensor intermediate connector terminal No. 2.
Alternate method
pic 3
1. Disconnect all ECM connectors or PCM connectors. Connect the check harness special tool (MB991923) between the separated connectors.
pic 4
2. Connect the oscilloscope to check harness terminal No. 104. (Check the camshaft position sensor signal wave pattern.)
pic 5
pic 6
3. Connect the oscilloscope to check harness terminal No. 103. (Check the crankshaft position sensor signal wave pattern.)
Wave Pattern Observation Points
1. Check that cycle time becomes shorter when the engine speed increased.
Examples of Abnormal Wave Patterns
pic 7
Example 1
Cause of problem
- Sensor interface malfunction.
Wave pattern characteristics
- Rectangular wave pattern is output even when the engine is not started.
pic 8
Example 2
Cause of problem
- Loose timing belt.
- Abnormality in sensor disc.
- Wave pattern is displaced to the left or right.
_________________________________________________________
Here are specific directions for testing the coil and power transistor.
Ignition Coil
Vehicle Power-train Management Ignition System Testing and Inspection Component Tests and General Diagnostics Ignition Coil
IGNITION COIL
IGNITION COIL CHECK
Check by the following procedure, and replace the coil if there is a malfunction.
PRIMARY COIL AND IGNITION POWER TRANSISTOR CONTINUITY CHECK
NOTE: An analog-type ohmmeter should be used.
NOTE: Connect the negative probe of the ohmmeter to terminal 1.
CAUTION: This test must be performed quickly (in less than 10 seconds) to prevent coil from burning and ignition power transistor from breaking.
pic 9
1. Connect and disconnect 4.5 - 9.0 V battery between terminal No. 2 and No. 3, and observe the ohmmeter whether there is continuity or not.
pic 10
2. If results do not agree with the table, replace the primary coil and ignition power transistor assembly.
SECONDARY COIL CHECK
NOTE: It is impossible to check the secondary coil through the continuity check as a diode is integrated in the secondary coil circuit of this ignition coil. Accordingly, check the secondary coil in the following procedure.
1. Disconnect the ignition coil connector.
2. Remove the ignition coil and install a new spark plug to the ignition coil.
3. Connect the ignition coil connector.
4. Ground the side electrode of the spark plug and crank the engine.
5. Check that spark is produced between the electrodes of the spark plug.
6. If no spark plug is produced, replace the ignition coil with a new one and recheck.
7. If spark is produced with the new ignition coil, replace the old one as it is faulty. If no spark is produced again, the ignition circuit is suspected as faulty. Check the ignition circuit.
I noted you are looking for connector info related to the ECM. My manual shows a five connector ECM. The last pics are related to and the 5 connector. It shows terminal voltages.
Terminal Voltage Check
Vehicle Power-train Management Relays and Modules - Power-train Management Relays and Modules - Computers and Control Systems Engine Control Module Testing and Inspection Pinout Values and Diagnostic Parameters Terminal Voltage Check
TERMINAL VOLTAGE CHECK
CHECK AT THE ENGINE CONTROL MODULE (ECU) OR THE POWER-TRAIN CONTROL MODULE (PCM)
1. Disconnect the ECM or the PCM connectors B-18, B-19, B-20, B-21 and B-22, and connect check harness special tool MB991923 between the ECM connectors or the PCM connectors.
2. Measure the voltage between each check harness connector terminal and check harness connector ground terminal (No. 25 or No. 29).
Check Harness Special Tool MB991923 Connector Terminal Arrangement Part 1
Pic 11
Check Harness Special Tool MB991923 Connector Terminal Arrangement Part 2
pic 12
Check Harness Special Tool MB991923 Connector Terminal Arrangement Part 3
pic 13
Check Harness Special Tool MB991923 Connector Terminal Arrangement Part 4
pic 14
Check Harness Special Tool MB991923 Connector Terminal Arrangement Part 5
pic 15
Check Harness Special Tool MB991923 Connector Terminal Arrangement Part 6
pic16
Check Harness Special Tool MB991923 Connector Terminal Arrangement Part 7
pic 17
TERMINAL VOLTAGE CHECK CHART
_______________________-
Pic 18 shows the ECM I have in the manual.
I hope something here is helpful. Let me know what you find or if you have other questions.
Aug 25, 2020 at 6:35 PM
