That would be a blending issue would it not? I watched the AC compressor while my wife turned it on. It will run a few seconds, then kick out for eight to ten seconds. The compressor clutch will cycle on and off like that until you turn the AC off.
There is one other issue I forgot to mention. This started about the time the AC started going out. Sometimes, especially with the fan set to high, it will just stop blowing. Several seconds later, it will come back on by itself and start blowing again. It will do that even with the AC off and just set to "blow air". Does not do it all the time though.
I hate to spend $40.00 on a can of gas just to have access to a gauge to check the gas level, but I will almost bet it is full of gas. I tend to believe it is an electrical problem. Maybe the relay for the AC? Maybe it is weak and will not hold a latch when energized, and will keep trying, but just cannot hold a latch "on". I will attempt to find the AC relay and test it. I will sure do that before buying a can of gas.
Thanks
Apr 30, 2021 at 1:24 PM
(Merged)
