The truck listed above is a project truck (XLT model) I purchased a year ago. I have been doing major repairs on it. Finally got it running, took it to DMV, failed because they were unable to read the computer on the truck. It was stationary for a long time without a battery installed.
The following steps I have taken to get it to crank:
1- Battery is only a year old, I took it to AutoZone to have it charged up, now 13+ volts.
2- Replaced the negative and positive battery wires. No corrosion at all.
3- Replaced the starter with a new re-manufactured starter from AutoZone.
4- Replaced the starter solenoid on the fender next to the battery with a NAPA new.
5- Checked continuity for the starter to the solenoid to the battery, everything checks out okay.
6- Checked all the relay inside in the fuse box and in the engine compartment power distribution. Replaced some relays unrelated to the engine not starting. Also cleaned all corrosion from all the relay leads.
Still no change, truck will not crank. I need a checklist to troubleshoot further.
Jun 28, 2019 at 7:47 PM
