My engine is not starting up?
2003 HYUNDAI SANTA FE
155,000 MILES • 2.4L • 4 CYL • 2WD • MANUAL
FEELIE75
Soo, here's the facts :)
* car will crank over and over and over, but not combust and start.
* only seems to happen in the morning.
* i.e. after sitting for a while. (if I came home at 9pm and didn't try to start it until 8am)
* AFTER it's started, the car runs FINE. AND it will restart FINE for the rest of the day.
Now, after about 20 minutes of cranking, it WILL eventually start. And this always happens after it starts:
* SQUEAL SQUEAL SQUEAL. Some belt or something squeal loudly for about a minute.
* there IS a smell of burn fuel from my car after failed attempts of starting it.
OH, here's an interesting fact:
* I tried push starting and popping the clutch one morning after 10 minutes of failed cranking. THAT started it.
Side facts:
* I got the started replaced last fall. I suspect the inordinate cranking-over killed the starter so I think this is a side-effect not a cause. I had to push-start my car for 2 months before getting it replaced. then it died 3 weeks later after I cranked-over for 20 minutes one day. Got it replaced again and have tamed my crank-over durations to
Feb 8, 2015 at 11:42 PM
HMAC300
  • 48,601 POSTS
This sounds like a fuel pump or the crankshaft angels sensor has gone out. When you turn the key to the on position without cranking the engine over can you hear the fuel pump run in the tank for 5 seconds?
Please run down this guide and report back. scan for codes and check fuel pressure with a gauge auto parts rent it.
Feb 9, 2015 at 7:04 AM
FEELIE75
oh hmm hadn't thought about Renting a gauge. thanks!
The Check Engine light isn't on right now, but it has occasionally come on. The last time I was able to scan the code before it turned off, it returned Misfire Cylinder 1. But the car runs smoothly, but I've heard that's possible with newer cars, they can compensate for bad spark plugs, etc.. who knows...
the check light isn't on anymore, it turns off after a few days by itself.
I'll try to find a gauge today!
Feb 9, 2015 at 12:00 PM
FEELIE75
it turns out it was the crankshaft sensor FYI
Feb 10, 2015 at 4:56 PM
BENZENWENGER
  • 38 POSTS
My father got a 2002 Hyundai Santa Fe 4wd 2.7 with a broken timing belt that he got.
I got a used Motor with 75000 miles, put a new timing belt, water pump, spark plugs & Wires, New Crank Sensor, Cam Sensor, Coolant and hoses, Oil and Tranny Fluid, Coil Pack. has been running fine for the last month.
3/30/16 at 7am when my mother was on her way to work drove 10 miles then just died on her. Try's to start motor turns over just wont start
Pulled it home, Scanned OBll with no codes, Has Fuel, Has Spark, has good Compression, changed crank sensor, cam sensor, MAF Sensor, Oil Sensor, Throttle Sensor, Safety Sensor on Transmission
Jan 2, 2021 at 9:13 AM (Merged)
JOHNNYT73
  • 924 POSTS
did you check compression while you had the throttle open or closed? try it with it open. If for some reason the timing went out, and compression is going beck through the intake and the throttle is closed it may show good compression when its not.
BENZENWENGER
  • 38 POSTS
When closed 180lb when open 120lb, thought it mite have been a clogged cat so removed the exhaust pips still nothing??? maybe a bad ECM?
HMAC300
  • 48,601 POSTS
try resetting security system if no manual look online on how to reset for your car
BENZENWENGER
  • 38 POSTS
Tried that, put another coil pack on, swapped the ECM, took off the exhaust manifold so motor could breath better,bad wire harness? is there any place I could get a used or new one? for the motor compartment ?
HMAC300
  • 48,601 POSTS
wiring harnesses don't go bad that often. scan for codes to see if there is a problem or not and check fuel pressure with a gauge. otherwise you are just guessing
BENZENWENGER
  • 38 POSTS
Has got fuel, there are no codes coming up not one!!!, mite just turn it into a parts car lol
Do you have injector pulse?
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Check out this article to see, and then get back to us please
THARRISON4
I purchased the car last week and drove on the highway a week later and the car shut off on me while driving on the highway and will not start back up. I tried to start it but I heard a noise from the back and then smoke came from the tail pipe. I don't know what to do.
Good afternoon,
You need to check the timing belt. It may have failed. When it does, the crank and cam timing is off and the engine will stop.
https://www.2carpros.com/articles/how-a-timing-belt-works
To verify, do a compression test.
PETEHNSMOM
One day i went to the store and came out my car wont not start got a new battery and alternator still everything light up but car didn't start. i got a mechanic to look at it and they said it was my starter i replace the starter and then started it. it gave me a start but jerk like i was running out of gas. he said it was my fuel pump. got a fuel pump and he puts it in the car wont light up or nothing. he said my ignition fuse was blown. okay, so i get the fuse and now everything lights up and the car sounds like it is starting but still wont start. please help me.
Jan 2, 2021 at 9:15 AM (Merged)
Welcome to 2CarPros.
If the starter engages and the engine refuses to start, it usually is either a fuel related issue or ignition. First, take a look through this link. It explains the most common causes of a crank/no start condition.
Now what we have to do is check for spark and fuel to the engine. There are two ways to do this. First, and easiest, is to see if the engine will start for a couple seconds using starting fluid. If it does, it's a fuel related issue. If it won't even try to start with starting fluid, most likely it is ignition related.
If you feel uncomfortable using starting fluid, here are two links that explain how to check for ignition spark and fuel pressure:
Here are directions specific to checking fuel pressure on your vehicle. The attached pictures correlate with the directions, provide the manufacturer's pressure specifications, and tell what to check based on different conditions.
FUEL DELIVERY SYSTEM
Fuel Pressure Test
1. PREPARING
1. Open the service cover under the floor carpet.
2. RELEASE THE INTERNAL PRESSURE
1. Disconnect the fuel pump connector.
2. Start the engine and wait until fuel in fuel line is exhausted.
3. After the engine stalls, turn the ignition switch to OFF position and disconnect the negative (-) terminal from the battery.
Note: Be sure to reduce the fuel pressure before disconnecting the fuel feed hose, otherwise fuel will spill out
Fuel Pressure Special Service Tool
pic 1
3. INSTALL THE SPECIAL SERVICE TOOL (SST) FOR MEASURING THE FUEL PRESSURE
1. Disconnect the fuel feed hose from the delivery pipe.
Caution: Cover the hose connection with a shop towel to prevent splashing of fuel caused by residual pressure in the fuel line.
2. Install the Fuel Pressure Gage Adapter (09353-38000) between the delivery pipe and the fuel feed hose.
3. Connect the Fuel Pressure Gage Connector (09353-24000) to the Fuel Pressure Gage Adapter (09353-38000).
4. Connect the Fuel Pressure Gage and Hose (09353~41 00) to Fuel Pressure Gage Connector (09353-24000).
5. Connect the fuel feed hose to the Fuel Pressure Gage Adapter (09353-38000).
4. INSPECT FUEL LEAKAGE ON CONNECTION
1. Connect the battery negative (-) terminal.
2. Apply battery voltage to the fuel pump terminal and activate the fuel pump. With fuel pressure applied, check that there is no fuel leakage from the fuel pressure gauge or connection part.
5. FUEL PRESURE TEST
1. Disconnect the negative (-) terminal from the battery.
2. Connect the fuel pump connector.
3. Connect the battery negative (-) terminal.
4. Start the engine and measure the fuel pressure at idle.
Standard Value: 343 Kpa (3.5 kgf/cm cm, 49.8 psi)
Incorrect Pressure
pic 2
If the measured fuel pressure differs from the standard value, perform the necessary repairs using the table below.
Pressure Drops
pic 3
5. Stop the engine and check for a change in the fuel pressure gauge reading.
After engine stops, the gage reading should hold for about 5 minutes
Observing the declination of the fuel pressure when the gage reading drops and perform the necessary repairs using the table below.
6. RELEASE THE INTERNAL PRESSURE
Note: Be sure to reduce the fuel pressure before dIsconnecting the fuel feed hose, otherwise fuel will spill out.
________________________________
7. REMOVE THE SPECIAL SERVICE TOOL (SST) AND CONNECT THE FUEL LINE
1. Disconnect the Fuel Pressure Gage and Hose (09353-24100) from the Fuel Pressure Gage Connector (09353-24000).
2. Disconnect the Fuel Pressure Gage Connector (09353-24000) from the Fuel Pressure Gage Adapter (09353-38000).
3. Disconnect the fuel feed hose from the Fuel Pressure Gage Adapter (09353-38000).
4. Disconnect the Fuel Pressure Gage Adapter (09353-38000) from the delivery pipe.
5. Connect the fuel feed hose to the delivery pipe.
8. INSPECT FUEL LEAKAGE ON CONNECTION
3. If the vehicle is normal, connect the fuel pump connector.
_____________________________________________
I realize you may not have a fuel pressure gauge, but most parts stores will lend or rent one to you.
Let me know what you find or if you have other directions.
TO2LEGAL1
  • 8 POSTS
replaced plugs and wires now has crank and no start
SATURNTECH9
  • 30,869 POSTS
If changing the plugs and wires caused a crank no start maybe you crossed some of the spark plug wires to the wrong place?
TO2LEGAL1
  • 8 POSTS
only has the 2 plug wires that run to 2 single coils
SATURNTECH9
  • 30,869 POSTS
Alright let me get this stright the engine started and ran good aside from the cyl 1 miss fire before you changed the plugs and wires?Then from the moment you changed the plugs and wires you now have a crank no start?
TO2LEGAL1
  • 8 POSTS
yes. it did run rough but now cranks over but no start
TO2LEGAL1
  • 8 POSTS
ran rough
SATURNTECH9
  • 30,869 POSTS
Have you checked to make sure you have a nice blue spark on each cylinder?Also inspected the spark plugs to make sure the gaps arent closed up completly?Does it even try to start?
TO2LEGAL1
  • 8 POSTS
pulled no.1 plug see no spark when cranking over
SATURNTECH9
  • 30,869 POSTS
Have you checked all the fuses?Any new codes?
TO2LEGAL1
  • 8 POSTS
checked all fuses, no new codes. i replaced both coils and still nothing
CA7922303
  • 165 POSTS
New fuel pump, all sensors have been replaced. Crank sensor has an ohms reading, cam sensor does not. Fuse block ECU fuses show 12 volts. Fuel pump check shows 12 volts. Key in start position with good pump relay fuel line disconnected at pump, does not pump fuel. Jump pump relay fuel pump operates. pulled #2 spark plug cranked with plug connected to wire, could not see any spark.
SATURNTECH9
  • 30,869 POSTS
Did you check for power to the ignition coils?
Good morning,
Are there any codes set?
If you have power to the pump and there was no flow, the pump is not working.
You need fuel pressure to run. It will turn on for 2 seconds with the key on for priming and will be on full when cranking.
Did you check for spark at the plugs?
Did you check for compression?
TO2LEGAL1
  • 8 POSTS
i do not have any power to either coil when cranking over
Jan 2, 2021 at 9:16 AM (Merged)
CA7922303
  • 165 POSTS
Fuel does pump with key on, there is uniform compression, there is no spark. Unable to see spark with plug installed in wire and unable to feel spark with screwdriver in wire and touching screwdriver.
TO2LEGAL1
  • 8 POSTS
neighbor mentioned something about a ignition misfire sensor/ignition failure sensor???
What is the fuel pressure?
What is the compression?
When you crank it does the tach move up a little to show RPM?
SATURNTECH9
  • 30,869 POSTS
Follow the trouble tree i posted let me know what you find.
CA7922303
  • 165 POSTS
Compression is about 190, unable to read fuel pressure due to sealed fitting on fuel rail. Do not have adapter to fit at this point, tachometer does not move, got about 9 volts on one pin of coil pack connector with key on. 0 at other 3 pins. Is this reading correct for power to coil pack?
RHOLANE
  • 5 POSTS
Maybe it could be a bad NO.1 wire? Do you have another new wire to try or use one of the old wire to see if you can get a spark?
No, it should be battery voltage. 12.2 volts or more.
No tachometer signal could be the crank sensor.
CA7922303
  • 165 POSTS
Crank sensor shows an ohms reading. Should it have no reading if bad?
CA7922303
  • 165 POSTS
What would be the correct way to test the voltage at coil pack? Maybe I'm not doing something right?
I attached a diagram of the coil for you.
The green is powered by a fuse I circled in one of the diagrams.
Check for power and let me know.
CA7922303
  • 165 POSTS
Crank sensor shows a reading of 630 on the 2000 ohms setting with negative lead on the center pin and positive lead on the pin left of center. Does this reading show a bad crank sensor?
