Engine stalls
1995 NISSAN MAXIMA
135,000 MILES • 6 CYL • FWD • AUTOMATIC
BIGGESTBOSS
  • 6 POSTS
The transmission also drops down in a lower gear sometimes while driving could this be the problem?
Oct 28, 2018 at 6:55 PM (Merged)
BIGGESTBOSS
  • 6 POSTS
The dash lights don't come on right when the motor stalls they light up a few seconds later
KHLOW2008
  • 41,814 POSTS
I believe you have a problem with the ignition switch. It fails to work after heating up and that is the reason the dash indicators do not light up when engine stalled.
CADIEMAN
  • 3,544 POSTS
check the chargeing sys. to make sure you working with proper voltage.then the fuel pressure.after that check the electrical.
BIGGESTBOSS
  • 6 POSTS
Are you sure it isnt the intake gasket leak that I have? Could that be triggering the map sensor?
NISSANLOVE
  • 5 POSTS
1996 Nissan Maxima 6 cyl Automatic 93,652 miles
I have a 1996 Nissan Maxima. For some reason it shuts down on me, usually when I am at a red light. It starts right back up. I have had the fuel pump changed, the gas filter, the spark plugs & the knock sensor, which I thought was the original problem. I still have no idea why this is happening. It's been going on about 3 weeks now, and it ran fine without shutting off 1 day out of the whole 3 weeks. What can cause this? I am at my wits end.
KHLOW2008
  • 41,814 POSTS
Hi nissanlove.
Engine is stalling either due to idling speed too low or a fault with the MAF.
Get the IAC, MAF and throttle body cleaned and retest.
CADIEMAN
  • 3,544 POSTS
you need to start checking and stop guessing.
NISSANLOVE
  • 5 POSTS
I'll give it a try. Thanks.
BIGGESTBOSS
  • 6 POSTS
Thanks !!!
