Okay. That is a start. This code is not saying that the TCM is the issue. This could be the problem but if that is all you have, I would not pay $1,000.00 on just this.
This code is nothing more than informational saying that the TCM requested that the PCM turn the light on.
So, I suspect we have other codes that will point us in the correct direction, but your code reader was not able to pick them up.
Basically, the code readers only communicate with the ECM/PCM but when you have a code in a different module, those code readers are not able to pick it up.
However, this is exactly why GM put this code in there so that you can be alerted to the fact that there are codes in the TCM.
I would try and make it to a parts store as they should have a scan tool that will pick these other codes up.
See the info below on this code.
Sep 29, 2021 at 6:15 PM
