Four cylinder 1.8 L front wheel drive manual 105,000 miles.
The timing for my car recently slipped due to a broken tension-er spring. I have replaced the tension er, tension-er spring, idler pulley, timing belt, spark plugs, and plug wires with OE replacements.
I have the timing mark on the crankshaft pulley aligned with the "T" on the lower timing belt cover which puts the crankshaft sprocket key-way just past the 12 o'clock position. The timing marks on the camshaft sprockets are aligned. With the crankshaft pulley in this position the number one piston is down instead of being up.
When I can get the car to crank the engine sounds like it is missing, runs very rough, will shut off if I let it idle, and the exhaust smells like unburnt fuel. Any clues as to the problem?
Feb 16, 2010 at 9:55 AM
